How do you swap Kings springs ?
images
Works on my King spring every time, zero issues.
Spring Compressor
I made a spring compressor out of all thread rod, scrap aluminum and scrap steel. It uses a 4Runner screw jack to compress the spring. It doesn't scratch powder coating on the spring.
images
Which brand? I tried a set similar and the depth of the arms were too long. I hit the threaded body before grabbing the coil.
And even if I could clear the threaded body, the safety also didn’t clear
Looks like the same ones, mine are pro point - which is just a white label store brand (like harbor freight). The safety pins do take a bit to engage, I honestly don't bother with them. If you alternate between sides, and only tighten each one a bit a time they stay fairly straight and centered. I don't have any issues with hitting the threads however.
375421d1610735199-how-do-you-swap-kings-springs-img_2030-png
I like, you could rent that one out!
I had the same issue with 3 different brand of spring compressors. Yeah people said don't worry about it and just crank them down. I figured it wasn't worth safety issue to save some money plus was planning to take it in for alignment anyways.
Glad you eventually found a compressor that worked properly:thumb3:
Just an FYI for everyone debating spring rates and heavy armor.
Your nitrogen pressure needs to be at the right levels, as well as the proper spring rate for your personal driving comfort. A 650 lb spring will give you the ride height you desire, but may be a little stiff. There are compromises with every aspect of this, unfortunately.
I've had these shocks shipped with little or no pressure at all, and they should be around 150 psi. Which doesn't affect ride height too much, but will give you a proper functioning cycle of the shock under load.
With 300+ lbs on the front of my 5th gen with bumper, winch, skid plates, dual batteries, arb comp, and heavy cable, I was worried about 600 lb springs carrying the load, but it does quite well at my desired ride height.
I rebuilt my shocks fall of 2019 and discovered that my nitrogen pressures were quite low. Now at the right pressure, the truck is that much more capable of handling the rough stuff, even with all the added bulk. I had experienced the spring bottoming out when pushing too hard in the past.
Here is a pic of the nitrogen rig I built for checking and dispensing the proper pressures that King recommends. This will apply to the other brands of performance shocks as well. You have to use a no loss chuck because a standard tire guage will not give you an accurate reading and you will lose quite a bit of pressure using one.
So with 300lbs + of weight, your only running 600# springs?
I only have C4 low pro winch bumper, gobi rack and sliders with 600# springs with 11turn preload. I was thinking of trying out 650 or 700 so I can reduce preload.
Yes Sir 600# springs. My ride height may not be to your liking though. I went through hub to fender measurements with Filthy Motorsports and Ben said I was within the range of what he recommends. I could probably go with a 650, but I like how it's been driving now for years. The proper nitrogen pressures made a big difference too.
My kings are only ~ 3mo old. Hopefully the nitrogen levels are correct.
What is your h2f measurements?
Unfortunately I'm on the road working and away from my truck for the next week.
I've seen these shocks ship with no pressure at all.
I think some carriers have restrictions on this,
What is your fender to hub measurements?
center of hub to fender is 23.5"
I need secondary shocks. i was on the bump stops a lot in Baja and my wheel wells show it. Tires were full stuffed lol. Shocks were being overworked pretty good.
back end with kings and king hydro bumps worked flawlessley though. I also ran the toytec HD 2." springs due to the extra weight we brought for a week of camping.
Heavy plus on not over springing. I'm just under 300 lbs over stock in the front with winch, alum winch bumper, compressor and second battery. Just like most folks I thought for sure I needed to stick with 700lb springs for my KING setup. However, I'm running 650 and have almost zero preload getting me up to a little over 2.5" of lift. The ride is absolutely perfect.
Ambrose67
