How do your 2” Icon springs sit?
Agent_Outside
I’m looking for input on the Icon 2” lift standard load springs.
My measurements are:
LR - fender edge to center of hub 22” -> 24”
RR - fender edge to center of hub 21.75” -> 25”
Is anyone else’s sitting with that much lean? I verified the springs are sitting correctly in the spring perches both top and bottom. You can visually see the vehicle is leaning left when looking at from the back.
Shot in the dark here....but since they are off one inch from one another are you certain one spring isn't the 3 inch overland version?
with out going out to my truck and measuring, that sounds about right. I have a driver side lean spacer that I still have to install. hoping for better results.
The Overland version looks physically different as the top few coils are close together vs the rest.
Give it a week or two to settle. If the difference is still that much might as well contact them for a replacement
There’s no visual differences in the coils. I’d be ok with a little sag/lean but I do not want 3” of lift so spacing the drivers side and having both to high isn’t an option. I want 2.5” in front and 2” in the rear.
In that case get in touch with them about this.. I also had some difference at roughly 1" side to side.. but it did settle a bit.
Having gone through 2 full suspension setups, i noticed you ALWAYS get slightly more lift than advertised. Get it swapped if you are not happy with it.
