How fast is too fast for a 5th gen?
MLA
The 4runner is an amazing machine, but it wasn't designed to break any speed records. Still, I've found my TE to be great on long highway drives.
There are a number of highways in TX with a 75 mph speed limit, and most folks treat that number as a minimum speed. I'm personally comfortable up to 80 mph, maybe 85... maybe... but then I generally ease off the accelerator.
At what point do you start easing up on the gas pedal? I'm leaving this open ended, but let's assume a highway driving situation, with clear visibility, "good" road conditions and minimum load.
85 feels stupid fast.
I usually go 80 on those roads.
...don't think my tires are rated for much more than that, anyway.
I get frightened with anything over 60 mph..............................................................i can't drive 55. :lmao:
From the "Driving" Section of the 2015 4Runner Owner's Manual
"Do not drive in excess of the speed limit. Even if the legal speed limit permits it, do not drive over 85 mph (140 km/h) unless your vehicle has high-speed capability tires. Driving over 85 mph (140 km/h) may result in tire failure, loss of control and possible injury. Be sure to consult a tire dealer to determine whether the tires on your vehicle are high-speed capability tires or not before driving at such speeds"
Straight line driving gives one a sense of confidence. The vehicle "feels" safe since it is such a smooth ride for an offroader. Not the same when trying an avoidance maneuver at 85 mph +.
Just to be clear up front, I am not a slow driver, and only drive in the left lane, and rarely get passed. After my first long trip I found that it really does not like going over 80MPH. 70-75 seems to be ideal for this engine set up. With 85MPH limit in the west in places and roads I commonly travel 90MPH or more on that's a bummer. My 1996 Montero with 225HP and 37" tires and 4:88 R&P is happy at about 75MPH as well...That just seems strange to me. My 2005 Nissan Titan wont drive less the 90MPH, heck even towing :D Especially after jumping out of the 4Runner.
Stability at speed has never been a worry for me. I spent a lot of time on the interstates of West Texas going to and from rigs running 5 over whatever the posted limit was in open country. It has always been getting this unaerodynamic brick up to speed and holding it on any kind of upslope that bothered me.
:flamethrwoer2:
What a load of huey. I see this like those old cars that have the orange marker at 55mph, trying to convince you that anything more is unsafe. Your maximum speed is dependent upon the condition of your vehicle, driver ability, and road conditions. :driving:
For us the factory Dunflops (2014 Dueler HT 684 II P265/70R17) have an S speed rating, meaning thermal breakdown of the tire won't begin until you've been above 112mph for some time. Would I recommend this, absolutely not! For reference this manual is appropriate for any vehicle which ships with N speed rated tires. Most of us ditch the Dunflops for other (bigger/beefier/aggressive) tires anyway which usually results in lower speed ratings.
What concerns me most about speed in the 4Runner is the aerodynamics. Anyone from the plains can tell you that even a 15mph wind makes a huge difference in the handling of this truck, no matter which direction it comes across. Ensure you factor the surface wind into your speed calculations.
I agree with you, avoidance maneuvers above 70mph get interesting and can be very unsafe. You should be able to safely maneuver the vehicle to avoid collision with any unexpected object/vehicle/animal in the road. The more speed you have, the less deflection in steering you can use before the tires lose grip. Also the more quickly the vehicle will respond to your steering input so the yanking the wheel can land you in the ditch on the other side of the road very easily.
Obviously you need to see to avoid, so you shouldn't be going faster than you can react to what you see. In broad daylight on a dry long straight road you drive daily, you can safely drive faster than the same road wet, at night, or around a curve. Straight line, dry, with unlimited visibility on a road I drive daily, I've had the 4Runner up above 100 while passing other vehicles, obviously this speed was temporary and I didn't feel it unsafe. There's almost never a need for such speed, and it's rare to exceed 85mph even when passing.
Sidewall stress is also a factor in our vehicles. On a recent trip along our interstates I had an encounter with a rice burner muffler which bounced off the inside of my driver's front tire before going up into the armor. Nearly 800 miles later during an avoidance maneuver for something else in the road at 70mph the sidewall and the tire lost pressure rapidly. Proof that tires may not fail at the point of damage, but much later when you're not expecting it.
Know your vehicle, not matter what speed you drive. If you don't know the capabilities of your vehicle under a variety of conditions then you're not going to know how it will react when you encounter avoidance and emergency situations. Pilots frequently practice stalling their aircraft, engine failures, and other emergency procedures to maintain currency. Yet most of those who drive don't realize that a tire has too low of a pressure by looking at it, hence the advent of TPMS. When's the last time you checked six to make sure nobody was close and then did a panic stop/brake check? How about swerving to avoid an imaginary object in the road while still trying to keep in your lane? I think most of us on here take better care of our vehicles than most, and are more in tune to what's going on with the truck than needing TPMS. (It's just that the orange light is so :censored: annoying!) If you know something is wrong with your vehicle, take it easy.
Chances are if you feel a speed is unsafe then let off the throttle, and gently apply the brakes. Panic braking and overreaction with too much steering input cause accidents on their own. The law sets a speed limit as the speed they feel maximum for the road under general conditions, drivers should use this as a guideline and reduce speed appropriate to their ability and conditions.
What is the 5th gen limited to?
Unless you changed out the stock tires to something cheap, the 4runner will be limited before the stock speed rating of the tires.
92 pickup 4x4, auto v6, 4.88, and 30" tires is like 112.
3rd gen 4runner 4x4, manual, v6, 4.10, 32" tires, s\c is around 107.
Tested on a dry lake
going past 100 mph is nuts. The fuel gauge actually moved after that a little run.
Also trying to follow a Porsche Cayenne turboS through the twisty California mountain roads is extremely difficult.
This feels like a troll....
I believe the governor is around 160km/h. I've never hit it - between the lift and Baja Rack, etc, my 'Runner starts feeling squirrley and barn-doorish over 140. 130 is as fast as I normally would cruise if I'm in a hurry. As a guy who drives a lot for work, getting the speeding tickets isn't worth it to me, so I usually don't drive more than 10% over.
This post made me laugh hard.
There is some parts of the country I won't go UNDER 85 mph. But thanks for the warning mate
Hellamatic: the governor is just a bit before 180 M/H
Low speed cruising
My '13 LTD cruises at a very comfortable 55 MPH on the remote highways in AZ, speeding up to turn into to the next passing lane for those behind, letting the cruise control downshift down the hills. 120 miles from the 1,200' desert to 7,500' mountains and a 4WD road into my cabin at 5 to 15 MPH for 20 miles. This rig is over 6,000# fully loaded, gets 16MPG on the round trip. It is a most pleasurable ride I make every 2 weeks, no white knuckles on the steering wheel, climbing downshifts below 3,000 RPM, no adrenaline. Always a nice way to begin and end 7 to 10 days in the middle of the Tonto Forest a mile high.
