How many miles do you have on your 4th Gen??
98,000 miles
2003 V8-4x4 Sr5 "B" package
(almost a "sport")
Full time 4wd
-Timing Belt and water pump
-Alternator Belt
-Oil Change and grease every 5,000
Toyota OEM (ESSO) 5w30 oil and
Toyota filters.
Note: picked up a 12 pack of Chevron oil I got at Costco for cheap that I will be trying next oil change
-Air filter
-Brakes (fronts rebuilt)
-New Battery
-Recommended transmission, transfer case, differentials, and coolant drain and fills
-A couple cabin filters a year
Maintain the exterior with clay, polish, and then wax.
Just bought a '05 SR5 V8 AWD with sunroof a week ago
- 92k
- just had timing belt, water pump done
- new plugs
- coolant flush
I was looking at other 4R's but decided on this one in my price range as it has the vvt V8 and lots of getup. Freakin love this rig so far and have lots of plans for her...
2008 SR5 4X4 V6. Took ownership at 10,000 miles on the 1st of November 2008.
Just turned 72,000 miles last night.
Oil and oil filter changes every 5,000 miles using Mobil 1 synthetic and OEM filter.
Replace engine air filter with Fram filter every third oil change (15,000 miles).
Replace spark plugs every 30,000 with OEM.
Grease drive shafts and rotate tires every 10,000 miles.
A couple of cabin filters every year.
I do all the maintenance myself. The stock radio was replaced at 30,000 miles due to an overheating issue by Toyota with an "updated" radio that looks the same. This is the only part that has "needed" to be replaced. I suspect I will be replacing the "updated" radio this summer due to the same thing. Next up will be trans, diffs, and t-case fluid changes.
2006 sport 4x4 v6
45,500 miles
Oil change every 5000 miles with Pennzoil Ultra 5w30. Toyota oil filter
@30k: Spark plugs, diffs/transfer case fluid, cabin filter.
@40k: Front brake pads/rotors.
2005 V6 Sport
102,000 miles
Oil/filter changes every 5-6k, swiched to Mobil 1 Syn at around 35k miles
Normal air filter/cabin filter changes
Plugs at 40k and 80k
All diff fluids changed 45k
Front pads and rotors at 98k
new tires at 55k
Never been to a shop of any kind except for a few of the first oil changes and the new tires. I do all regular maint. myself.
38k. Oil changes every 5k. New air filter at 27k. New spark plugs and diff fluid change at 33k. Grease drive shafts at 37k.
AMSOIL all the way!
2005 Sport Edition,
4.0 V6, 4WD
100,120 KM (62,211 Miles)
Amsoil Synthetic, Toyota OEM filter (used NAPA gold frequently in the past)
Change 4 times a year ~ 4,000 KM (Winter/Spring/Summer/Fall)
03 sr5 115k- oil every 5k, air filter here and there. starts everytime. just put in the 3rd new battery.
58k here an running strong. Not looking forward to the 60k maintenance though, even though it will be a few months before I get there!
06 SR5 v6 90k pull a decoy trailer every weekend for 4 months and pull a pop up trailer 6 times every summer.Done this for four years straight without a hiccup.Ya gotta love them yotes!.
