How many miles on your 4runner?
I purchased a 2000 Limited with 266,300 miles last November. It now has 273K. It runs and looks great, but since I bought it I have had the "strawberry milkshake of death" which meant I needed an engine and transmission flush (25 gals of flush), and a new radiator. I've also replaced the rack & pinion, and front and rear brakes plus master cylinder. I expect to get at least another 75K miles out of it.
Be positive my friend. I'm thinking 100k+ more for you.
305k on my 2000 limited 4wd w/locker. Bought her 10 years ago with 145k and to this day, she has never let me down, well almost LOL but the orginal alternator was failing on me pulling up to Denver. I have been doing the general maintenance and occasionally look in the engine bay and see what else needs replacing.
357,600 miles
Recently changed my engine oil and filter. And 8 months ago replaced my Flex Plate.
Next is to rebuild my failed power steering rack. :pizza:
230k on mine! Although, I have very little history on previous owner(s), and it looked like it wasn't taken care of whatsoever when I purchased it. Hoping I can at least get 300k out of it after all the work I've put in to it.
Just picked up Green 1996 SR5 4WD V6 in very good shape. 215k on ODO.
Zero Rust. Not even surface rust. Got to love PNW cars.
Needs some love. (torn CB boot. Motor caked with oil from VCG leaking over the years. Needs fluids changed everywhere most likely. Get good interior cleaning)
New Owner, 248k
I just purchased a 1999 4R Limited 4WD with about 248k miles. Had to replace the timing belt and water pump. Front wheel bearings were bad (and seized into the knuckles) and the rear differential carrier bearings are probably bad.
It has trailer brake controls installed. It makes me wonder if one of the previous owners towed something heavier than he should have.
Heater blend door Bowden cable is also sticking (with the consequent motor actuator burnout.)
Other than the thousands of dollars in repairs...it's in great shape!
275K miles and still going strong.
My 2001 (original owner) now has 552,300 miles on it. I took it on a 3,300 mile trip to Key West, etc. in January. No biggie.
Andreas
315,xxx on my 06 Sport. Im going to replace the worn out X-REAS for a conventional strut/shock system this summer.
Otherwise runs like a top
Andreas
Andreas I always love seeing your username pop up on any of the threads, lol. I know that thing is still moving right along!!!
My 2001 currently sits at 336K smiles and I'm the 2nd/3rd owner of mine. Bought it w/ 191K in February of 2013.
1998 LTD, 244K. Bought for my son in 2019. Runs/drives great - I'd take it across the country in a second. Air conditioning is the coldest of any vehicle I've every owned...
Only 287,5xx on my 1998 SR5 I've had since I turned 18 (dad drove it first original 2 yrs). It's been passed to my sister for a while over the years, and my dad used it to haul stuff when I was out of the country, then claimed it back and still use it as my daily. Trying to learn how to do maintenance myself to save some bucks. Great site with lots of knowledgeable members here!
rebuilt the powertrain @ 271,500 miles. Maybe could have just done the heads and gasket, but I wanted to drive this lil truck for a while so a reman "taco yota" 5VZ from Mexi, local rebuild on the Aisin box and SHAZZAM!
Still needs front axle redone, but hope to see 500K over my ownership.
tssawlson538
