How much should i look to be charged
ACarter
How much should I be charged for Bilstein all around and daystar 1.5 in the rear? 4 wheel parts said it was going to be a 6hr job and around $635
For a shop that's going to be a pretty average price. Did that include alignment
Sent from my SAMSUNG-SM-G890A using Tapatalk
Did you get ny other quotes? I would check some other shops and go from there.
Seems to be very hit or miss depending on a lot of things.. Location.. Demand.. Experience.. etc.
There was only one local shop I felt ok doing it, and they wanted $600 + alignment.. For that price one could buy virtually every single tool they need to do the lift, from jack stands to torque wrenches.. Fortunately I have all the tools and decided to save the money and do it myself, it's pretty straightforward.
FWIW - it doesn't have to be a suspension shop. Those items are pretty straight forward bolt in parts that any repair shop could install. I'd try a local tire and brake place and see. I used to work at a tire shop and we also did a ton of suspension and brake work. IMO it's a 2 hour job max plus an alignment. I could do it easily in 2 hours in my garage without a lift. Plus an alignment. I'd say $300-350 including alignment would be what I'd expect.
2hrs!? I must have screwed something up. I did 1.75" lift with the 5100s and it took hrs to get them reinstalled. Getting the originals out, quick and easy. But getting the LCA down enough to get the new shock in was horrendous. Is there a trick I missed because I thought for a while there there was no way I could get that shock back onto the LCA. I had to stand on the LCA and it still barely would go low enough to get it in there. I keep hearing how easy it is and it all is except that one part and I'm not sure why.
You should have loosened the lca's bolts, then it would have just dropped easily out of the way for a quick install.
I've never needed to loosen the LCA bolts (although that is an option) it always slips right in. But you do need to remove the Tie rods... Then again, I'm usually working on a vehicle with aftermarket UACs. The stock ones need the connection to the spindle all way loose....
Nobody will really get this done in 2hrs... It's always more than that, even if you know what you are doing. I've seen peoples 2hrs... turn into 6. Then they say... well 2hrs was actual time with hands on the truck.... 5hrs is fair.
I paid 600$ for Toytec kit + UCA's install. They also mounted, balanced, and aligned. Included re-torque and re-alignment if needed. I second not letting 4wp anywhere near your vehicle overpriced and surprisingly under experienced.
Exactly. Which sucks because it's causing you all this trouble.
Actually no trouble at all now. Had the same shop tweak the alignment a bit and rebalance the front wheels. It's all good now. Had to make another trip up there, but I'd much rather do that than pay an extra $300-$400. You can keep trying though.....
Keep trying what?
