How much will my new lift settle? Bilstein 5100 +Toytec/SAW Coils....
Tires added 1" of lift to the "Floor to Fender" measurements from yesterday.
255/75/15 ST Maxx. No wheel spacers. Zero Rub anywhere.
i like that you went with the 255/75/17's but i'm a bit surprised it added 1" because it's actually the same diameter as the stock dunlop at20's (based on cooper's and dunlop's sites - both ~31.7" diameter).
Update on lift achieved. Nearly no settling on rear.
Front Driver 2.875
Rear Driver 2.5
Front Passenger 3.0
Rear Passenger 2.25
Alignment is done. Everything is within spec. Caster got to 2.8 & 2.4. Good enough for me.
By Any Chance do you have the ground to fender measurements? appreciate it. one more thing did you add the 1/4 spacer in the front driver?
Looks great currently I'm running the 5100 with stock ft springs and I just purchased toytec springs like you they told me to keep it on the bottom clip but I would like to run it 1 clip up were you aware of any shock problems ?
When you say you ran it on 4th notch does that mean the 0” setting? And the eibach 1.5” lift springs brought you up to over 3”??
TerryNap61
