How-To: 99+ Center Dash Conversion with Wiring
alexb
This is my write up on everything it took to convert the center dash and console in my 1997 to that from a 2002 sport edition.
(minus defrost switch) Still working on that one
DISCLAIMERS:
***This is for REFERENCE only... I will not be responsible for anyone breaking their cars or causing any electrical problems***
During this conversion we used several different resources to figure out the wiring of the ECT PWR, Rear window UP and DOWN, HAZARD switches and dash lighting for all switches.
When doing the re-wiring we found that the color-coding can very from year to year and even with different options. For instance, the 99 hazard wiring from DirDawg's car was different colors than the 02 even though they are the same plug and pin layout.
Now onto the conversion
I located all the necessary pieces for this conversion from a 2002 Sport Edition 4x4 that I found at a local salvage yard. From that I took the following:
Center console and cup holders
Trim piece around shifters
Trim piece around guages
Trim pieces around the center dash
New air ducting for relocating air vents (THIS IS KEY, otherwise the new air vents will not line up and blow into the back of the stereo, climate control etc)
HAZARD Switch and wiring harness plug (get the plug for wiring color reference)
Combination switch for ECT, Defrost, Rear window Up Down
Wiring harness plug for combination switch
I started off by doing the center console swap following the write up on the forums
IMG_20120421_005819_800x600-1.jpg~original
After that I removed all the trim pieces around the shifter and center dash
IMG_20120422_182338.jpg~original
Once the trim pieces are off you can swap out the new air ducting. The old and new are both held on by one screw and fitment should be the exact same. You should be able to wedge the old one out and new one back in with a little wiggling.
IMG_20120421_155109.jpg~original
Next I separated the wiring for the ECT and Window switches that ran to the old center console from the BRAKE indicator switch and re-routed those up the dash. You can see them hanging out below the air vent with the other connectors
Next we began on the re-wiring of the new switches. The new dash has one piece that contains all the switches for the ECT, defrost, and windows that all use one combination plug for everything.
**Note this is where things may vary depending on year and model. I used a combination of wiring diagrams from a Haynes manual for 1996-1998 model 4Runners, Tacomas, and T100s, along with a FSM for a 2002 4Runner, and just by referencing all the plugs I pulled from the salvaged 4Runner.
This is a good source for 4Runner FSMs HERE
For all of the wiring we used crimps and heat shrink to make all the connections.
These are all the color combinations we found for the re-wiring
Left is the wiring from the individual old switches plugs : Right is the wiring from the new single combination switch plug
The colors are as follows:
LG = Light Green
BK = Black
R = Red
G = Green
W = White
BL = Blue
Y = Yellow
Starting with the rear window switch it goes:
OLD SWITCH LGBK ------|------ RBK NEW SWITCH
OLD SWITCH RBK ------|------ R NEW SWITCH
OLD SWITCH (Combine GBK & WG ) ======|------ BLW NEW SWITCH
Then there is a leftover G ground wire from the light in the switch.
For the ECT PWR switch: This one matches old to new
OLD SWITCH BKY ------|------ BKY NEW SWITCH
OLD SWITCH GR ------|------ GR NEW SWITCH
For the Dash lights in the Combination switch I used the wiring from the lights to the ECT PWR switch:
OLD SWITCH G ------|------ WG NEW SWITCH
OLD SWITCH WG ------|------ G NEW SWITCH
This is what it looks like with the lights hooked up in the combination switch piece
IMG_20120423_193906.jpg~original
This will leave 3 wires remaining on the plug for the new combination switch GR, GBK, and WBK
These 3 are all for the defroster but I have yet to get it to work and stay on. I have gotten it to turn on when you hold the button down, but it will not toggle on and off like it should.
Next is the new HAZARD switch. For this the actual connector is the same so I just changed the pin configuration. To do this, pop off the clip that holds the pins in, then pull each pin out. It is recommended to disconnect the battery as there is an "always on" power source to this switch.
The way I finally got this to work was to go back to the salvage yard and get the plug and wires for the new hazard switch. Then I just cross referenced the color codes from the old switch to the new. The color codes can be found in the manuals but they do not show the order they go into the pins of the connector. This is why I had to go back and get the actual connector, even though I didn't actually end up using it.
This is how mine ended up for the pinouts: There are 10 pin positions total in the plug, 6 across the top, and 4 across the bottom, 2 on each side of the release tab. Only 8 will be used as there are only 8 wires total.
[ ] [ ] _____ [ ] [ ]
The colors I used go as follows:
[GR] [BLW] [RBK] [G] [GW] [ ]
[GY] [GBK] _____ [ ] [BLR]
That should be it for the wiring. Next I just wrapped up all my wires with some electrical tape and tried to fit them back into the center dash. Then just assemble everything back together. With the extra wires you will have to shove things around to get it to fit behind the new air vents, but it should all fit.
Now you have a new and updated Dash!
IMG_20120426_164250.jpg~original
A few things I noticed along the way. Almost always, the light inside a switch will use the G and GW wire colors. Also, the clock is the exact same from old to new so if you don't find one with the new piece your old one should fit.
For the wiring, if your colors for your year end up being different, just try to find a diagram from the FSM and follow the routes to each wire. We re-drew them on pieces of paper to help understand where everything went.
Big thanks to DirtDawg for helping me out on this!
I am by no means an expert at this stuff, I just have some basic mechanical knowledge and sometimes had to work through things by trial and error. I blew a few fuses along the way, but it all worked out. If you need any help post here and I'll do my best to assist you.
Oh and one thing I left out is the 2 additional power outlets. I haven't done them yet, but I just plan on tapping them into the main one that is already there. Unless anyone has any recommendations.
Nice writeup on a great upgrade! Haven't seen this flavor before, I like it! If I had a '96-'98, I'd do this whole thing like you did...not just the center console.
Thanks. Yeah when found the new center console I knew something was going to have to be done with the ECT and Window switches as far as relocating them. Since the rest of the interior was still good in the salvage car I said what the hell and just grabbed everything.
I painted the plastic cup holder piece with plastidip to cover up all the scratches and it looks good as new now. Whats great about the pieces I found is they had this ugly faux trim stuck on them over the silver so once I peeled that off they were in perfect condition.
Cool but what was gained?
I have a 97 Limited and my dash works fine. I dont see any advantage to this modification.
Your writeup appears to be very good though!
Mainly just for looks. Also when you get the updated center console with cupholders you lose the place for your rear window and ECT switches. The new dash has them located in a different place (just under the air vents and clock), but requires re-wiring them to the new style switches.
Looks is about it, you end up losing 2 cupholders, so instead of 6 you end up with 4, i frequent my dash upholders despite having the center console ones.
Someone else finally figured it out, up until now one other guy did this.
Hey ok Ill tell yea how to get the deforst to work if u can send me a pic of the back of the white plug that gose to the new bezel. Ok we'll u need to keep your old hazard switch and solder the wires in
Anyone with a pic of the white plug? That's all I need to finish
Hey sorry. I've been away from the forums for a while. I'll see if I can take the dash off and get a pic for you this weekend, if you are still needing it. With winter around the corner it'd be nice to get the defrost working.
GREAT Write Up.
I just finished this today - along with some LED upgrades and a new whip mod - I am one happy camper. I even hit the new 99+ panels with some SEM and everything looks 100%.
A couple addendums I wanted to add for my 1997 (in Bold).
OLD SWITCH BKR ------|------ BKY NEW SWITCH
AND
This will leave 3 wires remaining on the plug for the new combination switch GR, LGBK, (I think this is what you meant, you just didn't specify) and WBK
I didn't give the defrost a shot (in Florida, it's a moot point). But, for the two new A/C ports, I just tapped into the existing cig lighter. Everything works on the two new A/C ports, but the original cig lighter pops the fuse when I use it... not sure what's up with that.
All in all, a great day.
-M
I looked into this a few years ago, but i am glad I didn't do it, I love having 4 cupholders!
I agree, having the extra upper cup holders is nice with the 5speed and plus they hide away like they aren't there. So much in fact that if I had a 99-00 5speed I would look into getting 96-98 in dash cup holders. Straws and taller cups go in the indash cup holders . Change and small cups/bottles go in my 99+ console cups.
I do like the silver dash cover though. What 4Runners did that come on?
02 Sports came with silver, thats the only one i know of.
And yes about the drinks with straws, everyday my father leaving a large cup with a straw in it in the center console, stabs my arm every day on it.
Yeah, I've never actually used those and needed to fix a couple other issues with my dash. I like it. =)
But really, I was posting to try and get ideas on the popping fuse.
GREAT Write Up.
AND
-M
Not sure why the fuse would be poping. I did the same thing, just tapped into the original cig lighter wires for the 2 new outlets. Are you using them all at the same time?
No, after I was done, I just went through ow by one to see if they were working.
The new ones were fine, but for some reason the original one keeps popping. I'll have to take another look at the wiring. I'm sure it's something dumb.
-M
Sequoia Limited Fuse popped too
Every time I used more than one of the 3 cig plugs up front in my '01 Sequoia it would blow a 20 amp fuse too.
DJNutshell
