How to: Disable DRL on your 3rd gen. (earlier models)
trd_4runnin
Well, I know this seems to be a pretty talked about topic on this forum as well as yotatech and when I was searching for info on how to do it, I found a lot of confusion as well as misinformation. I tackled the DRL disable and it was fairly simple so I thought I would snap a couple pictures and do a write-up. Might be nice to sticky this somewhere since it seems there are a lot of people interested in doing this.
From my understanding this will only work on earlier models of the 3rd gen 4Runner (1996-2000?). Someone please correct me if I am wrong.
The first thing you are going to want to do, is locate the battery.... should be easy enough. After you have found the battery you want to remove the nut that is closest the windshield on the battery tie-down bar. (Mine was a 12mm, you will want to hold onto the rod that the nut screws onto as it will be loose after you remove the nut.)
This is the nut:
P7290021.jpg~original
After you remove the nut, you will see what I mean about the rod not being connected to anything on the other end. To make sure I didn't lose it, I just took the rod off and threaded the nut back on.
Rod and Nut removed:
P7290022.jpg~original
Once you have this removed you should be able to lift up on the tie-down bar enough to slide the battery over about 6" away from the fender. This will give you plenty of room to work. There is a box hooked to the fender, and there is a clip right off of this box that you need to unplug.
This is the box:
P7290023.jpg~original
Now, you may be able to reach down and seperate the clip on your own, but since I have bigger hands, I found it easier to just use a flathead screwdriver:
P7290024.jpg~original
Once you have undone the clip then you should have a situation looking like this:
P7290025.jpg~original
Your DRL's are now disabled and you can put everything back together and drive off into the daylight!!
This was my first write up ever so if it sucks.....
...Then BACK OFF!
I just stumbled on this. DRL are day time running lights correct?
Why would you want to disconnect them? Is there a benefit?
What's next disabling the airbags? I don't get it why are people worried about this?
I dont get why you are worried about people being worried about it. No one said that you have to do it. If its not for you, thats cool just dont polute my thread with sarcastic nonsense comments about disabling airbags, which would be stupid even if it werent illegal.
This is the first vehicle I have ever owned that has DRL's. For that reason, im very accustomed to turning my lights on myself in fog, snow, rain, dusk, dawn...etc. I do not need DRLs in the middle of a nice sunny day. Its just pointless IMO. I disabled mine so that when I go to take pics of my truck on trails or wherever, I dont have to shut it off to get the lights to turn off and I get to work at night and sit in my car for about 15 minutes with 90% of the other employees. I like to leave it run while and dont like shining my lights at other peoples windshields.
I agree :cheers:
Thanks for your answers, makes sense. Sorry I wasn't trying to set up anyone to take my question to a level that I agree was a bit far with the airbag deal.
I didn't really understand why you wouldn't want them, but your reasons make perfect sense! I hadn't thought of that for photos...which I actually just got a photo of my 4Runner wheelin' and sure enough....lights!
Thanks for the response.
Sorry didn't mean to be a dick. I was just honestly curious what the reasoning was. I wonder if there is a way to integrate a switch into the DRL instead of a hard unplug, so you can still have the safety advantages on the street.
also if you did the H.I.D Plug & Play type, one of the head lights is on while the other one is off. Another reason why some would turn off their DLR.
trd_4runnin, nice work! Good pictures too.
I will say this, to finish this mod off (if you have not already done so), you probably should cover up both plug ends to keep dirt and water out. I'd take some electrical tape (or something similar) and wrap the heck out of both of them. Then take two zip ties and tie one around each connector to hold the electrical tape on. (The heat from the engine will cause the tape to come off if you do not find a way to keep it secured.) Just a thought.
I disabled my DRLs on my '02 a while back...have loved it ever since. I will say, I wish disabling '01-'02s were as easy as disabling them on '00s. Granted sniping one wire under the dash is easy, but unplugging a connector in the engine compartment is much easier IMO. My wife has an '00 4Runner and sometimes just to mess with her, I unplug her DRLs when she's not around (haha, she always tells me to leave her 4Runner ALONE!).
To my knowledge, no one has yet to come up with a way to install a switch inline to turn off/on the DRLs on '00 4Runners. That'd be nice to be able to do so. So far, the write up mentioned earlier in this thread is the only way I know off on how to install a switch inline...but that's for us '01-'02 guys.
Majority of people looking to disbable their DRLs do not know there are 2 specific ways based on what year 4Runner they have. Not completely sure if '99s came w/ DRLs, but the '00 guys do it one way, the '01-'02 guys have to do it a different way. Being that I have since disabled my DRLs a while back, I get asked quite often by fellow YT members how to disable their DRLs on their '00 4Runner. Your write up (along w/ pictures) would help a ton if you could post it on YT under the "tech write up section". Hope you can find time to add this to YTs site!
Here's the tech section I'm refering to on YT: Tech Section
Here's how to submit tech articles: Tech Article Submission
Oh and for all those how are curious as to why the need to disable DRLs, here are just a few reasons in this YT thread:Why disable DRLs?
For many more reasons as to why disable DRLs, just search the terms "DRL" or "Daytime Running Lights" in either T4R.org or YotaTech.com. This topic has been heavily discussed on both sites.
Again trd_4runnin, nice write-up!
Before I submit it to Yotatech, can you confirm the years that this method will actually work on, and good idea on the electrical tape!
After speaking with trd_4runnin, we have cleared up the issue why he has DRLs on a '98 4Runner sold in the US. I'll explain...
DRLs were available on US sold 3rd Gen 4Runners from 2000-2002. The model year '00 being the 1st generation of DRLs. The model years '01 - '02 being the 2nd generation of DRLs. However, 3rd Gen 4Runners sold in Canada, had DRLs earlier than '00. (How early, I don't know. Could be all the way back to '96.)
In short, his US sold 4Runner was had some work done to it and was reassembled in Canada. With that said, his DRLs were without a doubt added to his 4Runner when it was being reassembled in Canada.
Lucky you! You have a very unique accessory for your model year 4Runner.
EDIT: For those of you w/ '99 4Runners that have DRLs. Look on the inside of your driverside door jam where the door latches to find the month/year your 4Runner was produced. Maybe it was produced late in the year and therefore got DRLs. It's very possible many '99 4Runners came with factory DRLs based on what month they were produced. Otherwise, it could have been an accessory that was added either at the dealership or later down the road.
Dirt4dinner said:
Uh oh....I have them on my '99. Maybe it's a Canuk too.
Dirt, look on the inside of your driverside door jam where the door latches. Find the month/year your 4Runner was produced. Maybe it was produced late in the year. It's very possible many '99 4Runners came with factory DRLs based on what month they were produced.
Probably need to edit my post back up a few.
What a simple fix to an irritating for me issue. once i know what to look for it was right there in the open took 2seconds with the hood up now I wont be the only one off roading with my lights on:D
Funny i was just getting on here to look at how to do this I have question or idea... I'm Im about to do this in my 01, and my question is has anyone just tried getting a male/female end conector to put on both ends of the black/yellow wire so that when you want them you can just snap it in like the older 3rd gens?
I saw. A thread somewhere that the guy put in a switch
