How To Disable VSC Easily, Safely, and Un-Doable
mrpanic7
Hello! Thanks to the help of nicolachel, I decided to write this thread is a go to source for how to get "VSC OFF" without having to do any actual hardware mods to the ECU or wiring.
FYI-Not responsible for anything that goes wrong. Also any terms or info unclear in my write up, I will be listing this article that can be referenced.I will also be attaching the diagram that walks thru how to do a Zero Point Calibration, but you can reference just to see which ports to plug the wires to. I highly suggest reading over this article first, as it will give you a clear understanding for what you are doing.
http://www.toyota-4runner.org/probl...ac-vsc-off-lights-zero-point-calibration.html
Ok, that said here are the steps:
1. Ensure the shift lever is in
“P” Park.
2. Turn the ignition switch ON.
3. Using SST 09843–18040 (Which is that homemade tool, for mine I just used speaker wire) repeat a cycle of short and open between
terminals Ts and CG -Basically after having the end of the wire plugged into ports #14 and #4, using the other end, simply touch the wires together 4-8 times within 8 seconds.
3.Verify that the VSC indicator light is lit indicating
the recorded zero point is erased.
4. Turn the ignition switch OFF.
You're all done! VSC is now off. If you want to go back, simply follow the above article I posted.
averyberryman061493
