zcruiser
Senior Member
EDIT (07/17/2017): Updated images with links to PostImage (postimg.org).
Couldn't find a decent write-up on changing the spark plugs in my 3rd gen T4R, so wrote one up...
I bought six NGK BKR5EKB-11 plugs from Advance Auto for just under $26.
Tools needed:
- 5/8" Plug socket
- Ratchet and extensions (8" and 3")
- 10mm box end wrench (mine are ratcheting, very helpful)
- 10mm socket
- 8" parts grabber
- Dielectric grease
- Wire gauge
- Phillips and flat screwdrivers
- Nitrile gloves
NGK: BKR5EKB-11
Gap: 1.1 mm (0.043 in.)
Torque: 18 Nm (13 ft lb)
View of the plug locations on driver's side:
View of the passenger side, coil packs obscured by intake. I've marked the various things that need to be detatched, unplugged, or loosened on the intake to remove the section between the filter box and the throttle body:
1. Remove the wiring harness from the left side of the intake (2 places):
2. Remove 3 vacuum tubes from the box, loosen the upper and lower hose clamps.
3. Remove the lower end of the intake first, drop it down into the engine bay, pull upper end off throttle body, then remove the intake from the engine bay.
Now you can clearly see the 3 coil packs and the plug wires leading to the driver side:
4. Remove the 3 plug wires from the coil packs. Due to the custom stock lengths, there's not much chance of mixing them up so I removed all 3. If your plug wires are not different lengths, then removing them one at a time is advised. Release catch by sliding the tip of a flat screwdriver under the latch and pull up on the plug wire boot.
5. Unplug the trigger wire from each of the coil packs and remove the 10mm bolt holding it to the valve cover.
Changing the plugs on the passenger side is pretty easy, actually.
6. Remove the coil packs by pulling gently off the top of the plugs:
7. I used 2 extensions on my 5/8" plug socket to get to the plugs:
Pic of the 3 passenger side (NGK) plugs:
continued...
Tools needed:
- 5/8" Plug socket
- 10mm socket
- 8" parts grabber
- Dielectric grease
- Wire gauge
- Nitrile gloves
NGK: BKR5EKB-11
continued...
