How to keep cupholder inserts from popping out attaching to cup?
Unless you have one arm I would...use your other arm to pull it off. It's not that hard unless you are shoving a liter of cola in there.. Are you into liters of cola Farva?
I used Velcro to hold the cup holder in. Use a big piece and make sure you get a good bond. Still didn't work as well a my big Yeti tended to get stuck and pull the holder out, Velcro and all. Then, by mistake, one of those cardboard coffee sleeve thingys fell into the cup holder, and voila, it keeps your cup from sticking. So go to Starbucks, get a cup of coffee and your new T4R accessory.
I just put three small globs of RTV on the bottom of the cupholder and let it dry overnight and problem solved, done this about a year ago.
I was able to get my hands on a roll of butyl tape. It's like fun-tack, putty tack, or adhesive putty, but more aggressive in its bonding properties. It is removable.
Roll up a small ball and place under the holder and press down. Molds to the void/space.
Most of the days I use my 30oz yeti cup . The black inserts stays stock on the cup so I just lift and drink with the silly thing on, No biggie
The rubber cup holder stays with my drinking device until I leave the vehicle.
What I did was velcro the bottom of the cup holder. Sometime it would still come out. Then I cut a couple of 2.7" dia, .25" thick disks from some black rubber sheet I had laying around and problem solved.
It's the little things that drive people the most nuts, myself included. lol
Fleshlights? Twisting and pulling? I prefer pumping and dumping personally.
30oz yeti and knockoffs do this quite well. I've been throwing loose change in the bottom of the cupholder inserts and that keeps them from seating all the way down. Plus ever so often I can pick up a sammich with that change.
Been wanting to keep my truck cleaner tho so I'm going to go with velcro.
I keep a plastic bottle cap in the bottom of the cup holder. Yeti tumbler doesn’t stick or wobble.
Ambrose67
