How to know if I have xreas and daystar lift question.
knightsfs4
First off, I have a 06 Limited 4wd. How do I know if I have xreas? Also, do I have to get new shocks if I install the daystar 2.5/1.5 lift kit?
Xreas has hard lines that run from one shock down the frame and to the opposite corner shock. These lines transfer fluid. Yes DS 2.5"x1.5" works fine. Just get an alignment after the install.
Face the seam between front and rear doors. Get down and look at the side of the frame rail. If truck has XREAS there will be a very visible canister afixed there.
If you look at the front shock, you can see the line attached to it (the pic chaz posted shows this). Very easy to tell. If you do have it, no sweat as that kit will work fine with the stock XREAS system (works with or without it).
TerryNap61
