How to make spare chipped keys
Bought some blank keys from Amazon, got them copied at ACE, followed these steps in the first post, and got two new programmed keys for $7.99 ea! Worked great! Any new key made will become a Master key as well.
I did realize however, their are a few different "Chip Key" platforms. So be sure the blanks you purchase are specific to the vehicle.
Thanks! Saved me $150 per key at the dealership!
Help! All keys stopped working.
Anyone have issues with programmed keys that stopped working 2 weeks after programming? I successfully programmed two sets of keys, all worked great for 2 weeks and now none of the keys work, even the original master. The car is dead in the water. The dealer (not Toyota) where I bought it told me that it is a security feature that after two weeks the system shuts down without a code from the dealer. Views it as a stolen car.
This is what I purchased, a few weeks ago off ebay. Got it working with theseexact instructions. Love it!
i recently came across this and did my research both on here and on various other forums.
Some said that it has to be programmed by a dealer/locksmith and some said that only the keys with a small dot near the end of the key blade works. Some also mentioned that walmart/home depot would cut the key.
However most of those information might not be the truth based on my experience. I'm willing to provide a small guide on this for those in need.
how to get a key blank
i bought the key blank from a seller on amazon and there was no small dot on the key blade at all but it works.those found on ebay might also work.
So just buy the cheapest one which says "for 03-09 4runner"
should be less than 20 bucks shipped.
how to cut
i at first went to walmart but they refused to cut it because i didn't buy the key blank from them. Home depot and lowe's did the same thing.
So i asked a local locksmith and he did it for just 5 bucks. (just fyi those keys are made of brass, not steel, so most locksmiths would be able to cut them.)
how to program
actually it's a super easy if you still have one master key that can start your 4runner. There was a pdf somewhere about how to do it on a prado but
its not very clear(it would ask you to remove the key from ignition 3 times without mentioning putting it back in at all:eek:) so i'll try to provide a clearer one here:
1. Take the new key and one master key that can start your 4runner(old key) into the 4runner with you and close the driver's door.(immobilizer light should be blinking)
2. Insert old key, remove old key, insert old key, remove old key,
insert old key, remove old key, insert old key, remove old key,
insert old key (immobilizer light should be off from the first insertion)
3. Open and close driver's door six times (immobilizer light should be off)
step 2 and 3 need to be done in less than 35 seconds(pdf says 35 seconds)
4.remove the old key. (immobilizer light should come on(steady on, not blinking))
5. Insert the new key(immobilizer light should be blinking)
then just sit there and wait, after about one minute the blinking immobilizer light should go off and you're done.
Whole process need to be repeated for any additional keys, the just programmed key could be used as the "old key" for the additional keys.
If there are 5 master keys registered with the immobilizer, it won't accept any more(and i don't know how would it tell you this, so just do a erase if you can't get it to work after trying for a few times). You have to erase them using a similar method(bring in just an old key, insert+remove one more time and open+close one more time, after the 7th close of the driver's door the immobilizer light will stay lighted for one second, remove the old key quickly after that and all but that one you just removed are erased.)
if you don't have any working master key(meaning you only have valet keys). Then i've no idea what could you do other than ask for help from a dealership.
Total cost is less than $25 if you still have at least 1 working master key. Less than 1/5 of what my local dealership wants.
Hope this would be useful for those in need, please post your results if you decided to give this a try.
thank you!!!
Thanks! Spent $12.45 here. https://www.amazon.com/KeylessOptio...=1477579473&sr=8-4&keywords=2008+4runner+key&
Home Depot cut the Key for free.
Then programmed in the Home Depot parking lot and it works.
The first time I went to Home Depot the guy said they wouldn't do it because I didn't buy the key there and he put it in this sensor thing that said it had a chip, so he said he couldn't. I brought the key in the next time I went and after a really nice guy who worked there helped me out with something in the Hardware section I asked him about the key and he did at no charge.
I just got this key in the mail, will have to wait until next weekend to get to the dealer for my buddy to program it
Going to have my friends at the dealer cut the key by vin as I'm the 4th owner, had Home Depot cut a blank and it didn't turn well in the lock cylinders
Lol, that's because the guy who cut it was working in the blind and window treatment department the day before he was put in charge of cutting keys.
Any update on this? Anyone else run into this when programming their own keys?
I just paid a local key place $100 to cut and program another basic key for my '03. They connected a laptop to the computer port to program it. I feel stupid for not checking this thread earlier. At least it hopefully won't randomly stop working in 2 weeks..
Cut and programmed key to vehicle but the buttons are on a different frequency so it starts my 4R but the buttons are useless...
Did you check to make sure they were the same before you purchased?
What year and model is your 4R?
And did you do both programing steps?
Obviously you did the steps to program it to start your truck, but did you do the steps for programing the buttons as well?
06 V8 sport, yes did both, plus found out my courtesy switch is messed up but got it working enough to set it into program mode but keyfab wouldn't program
