How to remove the Tonneau cover bar from a 07 SR5?
kn1ghtrydr
What's up guys,
I was trying to fit my bike into the back of my 4R the other day and I feel like that bar gets in the way every time. It'd also be easier to sleep back there without having to slide under it haha. Anyways is there a pdf online explaining how to remove it?
Thanks,
Jay
Are you talking about that leather cover thing that extends over the back trunk area when you have your seats up?
If so, just disconnect the small plastic clips from your back seat headrests, then gently grab the railing that extends across your rear trunk and press it against either side of the trunk. It's got spring-loaded 'ends' that pop out, and they fit into the little holes in the plastic panels on left and right side above the wheel wells. Once you compress one side, just simply slide the other end out of the hole and you're done.
BillM777
