A 3.4 is a 3.4 is a 3.4. with MINOR differences.
Here's my question for you.
What is wrong with your motor?
MINOR differences between the 3.4L are:
Fuel Injectors
Throttle body.
HOWEVER!!!
Like I said before, a 3.4L is a 3.4 is a 3.4.
All you'd have to do is swap the upper part of the engine, IE Fuel Injectors and Intake, to make it work perfectly in your truck.
The Block, Head, Pistons, ect are all the same. Just MINOR differences between the small stuff.
If you need more info, look in the "Stuck" thread and get my info and either call or shoot me a text.
Any 3.4l will work. Be it out of a 4runner, tacoma, tundra, t100 or whatever. Anything differnent will be small and you have everything you would need to change over on your old motor.
None of the 3rd gen or 1st gen tacomas had drive by wire, dont know of any 3.4l or any pre 02 toyotas that had drive by wire. It was not until the 4th gen and 2nd gen tacoma with the 4.0l that drive by wire was used. So dont worry about that.
This is just flat out wrong. The 2001 and 2002 3rd gen 4Runners with the 3.4L V6 5VZ-FE (only motor offered) were equipped with throttle by wire. Viz:
Toyota 4Runner History 2001
Further, this section of the 2002 4Runner FSM describes the system:
Either way the TB can be swapped from the OP's original motor.
In all my years as a mechanic i have never seen a 5vz 3.4l with drive by wire. In fact i just did a bunch of work on a 02 Limited and it was a cable driven throttle. Now that said different years, countries, fed or cali emission could make the difference.
