I.D. this part...
2k4Runner
hey everyone, new here. anyways im trying to locate this piece, as i have no idea what its called. maybe one of you can help me out. i believe i had a rat/mouse that decided to make a home in my engine bay cause the wire was chewed all up and there were bedding material too!
anyways, the part in question is right behind the timing belt cover? and the wires from pic 2, connect to the wires in pic 3.
P1010003.jpg~original
P1010004.jpg~original
P1010005.jpg~original
thanks everyone! :)
hossmaster said:
Is that gizmo mounted there or is it just sitting there? Whats the story about that motor?
it's actually mounted there. supposed to be connected to each other. the motor is fine, it just wouldnt fire up yesterday. it would just crank but not fire up.
i just put in new wiring since no one could id the thing and it fired right up. did get a CEL later on to find out it was my knock sensor, which was also chewed up, and just replaced the wiring since a new one wouldve cost me $170ish. :D
ill take a look @ my truck tomorrow..coulda sworn there wasnt anything next to the PCV valve (around where that is located)
how do you wash it? I hear people who power wash it and their engine runs funny afterwards. If I do what do I need to protect from water.
You know I was gona say the knock sensor....:biggrin2:
And Mr. Dabadina your gona want to cover the intake and all major electrical housings. Most plugs and fittings will be protected from water.
lee said:
dude have you ever washed your engine???
why are there tons of leaves in there?
How long has the Runner been sitting dormant, if a mouse made a home?
Also do not pressure wash.
Just cover the vitals, air box, bat, etc, and then spray some simply green or some sort of engine degrease and use a regular hose.
Thundro
