I decided to test out the KDSS and A-Trac on my 15 Trail
Running boards
... I've got 6k miles and factory tires and I was able to traverse 6x6 pieces of wood, large moguls, steep hills with bad approach and departure angles and moguls with factory floorboards.
Do you mean those factory running boards? Those are damage enhancers. They'll cause more damage to the body if you ever scrape them. Take those puppies off. :horn:
I suggest looking at true rock sliders for rugged terrain.
Read this for ideas:
http://www.toyota-4runner.org/5th-gen-t4rs/195991-consolidated-slider-info-thread.html
I had sliders on my Tacoma and I have them on my TJ Rubicon. For what I want to use the 4Runner for I won't need them. That is another reason I took pictures was to show what it could do "stock". I can run light and medium trails and as long as I run a good line I won't need them. The frame is at the same height as the floorboards and that's why I didn't remove them for the test.
Congrats on getting your 4runner out and actually using it off-road. Atrac is pretty good in most moderate situations.
