I finally did it. But now I need tire recommendations
tekstrand
I finally bought my third gen! 1999 SR5 4wd with 213K on it. Excited beyond belief.
Right off the bat I need new tires, at least on the front but I'm thinking it may be better to just do all 4. Would love a recommendation for combo on/off road tires, below the $170 price point.
Your thoughts?
You need to do all four, or only use the 4WD on limited traction surfaces. The differences in diameter between new tires and worn tires (and tires from different brands) are significant enough to cause serious binding on pavement. So if you're planning on using 4WD for snow driving where you'll have patches of pavement in between, replace all four and keep them rotated regularly.
Do you feel I'm crazy for going under $170? I'm new to this so I'd love to hear your opinion/input!
For decent A/T tires you are looking at $190ish/tire. I am in the same boat as you, I need front tires. But I am just going to replace all 4 with either Duratrac's or BFG A/T KO2's. Both are around $190ish.
Congrats on your purchase. Do you plan on a lift anytime soon?? If no LT265/75/16 on stock rims. I had cooper AT3 c rated on my 96 really liked them on and off road and in the snow. Can find them fairly cheap through DTD u just missed there July 4th sale.
That is assuming you keep a standard load rating...once you jump to a E rating your starting at 190ish to 290ish. BFG load E will be 250.00ish.
Im also basing this off 17" wheels, so it may be a little cheaper on a 16".
That is just on the low side these days. I would recommend a load rating of E for stronger sidewalls, especially if you carry camping weight and air down the tires for rugged terrain.
I like the Coopers I also like the Nitto Terra Grapplers. I haven't run BFG's in over 13 years. I had Goodyear MTR's before they changed them, but those are not cheap at all.
No Snow, live in Austin Texas so the worst I'll have is slick roads from rain, and then a bit of light trail going. Nothing too crazy
Not planning on lifting right away so I'm going to stick to stock rims.
16" are a bit cheaper. Right now the KO2's in 16" only come in load range E and they are under $200. Same for the load range E Duratrac's.
With LT tires u get more tread depth more aggressive look and also a harsher ride. I had C rated AT3's and I felt every crack in the road, tires aired down to 28-30psi. I dont know if the harsh ride was from the C rated tires or recently installed shocks/struts stock Monroe sensatracs.
170??? Cooper ATP's are good and possibly still below 170.00/each
I second these tires. I have had them on my Runner for about 9,000 miles and they have been great for me.
Americas Tire (Discount Tire outside of California) has them at $145 a tire plus a $70 prepaid debit card rebate when you buy four. This is the same deal I had when I got mine.
So far I'm happy enough with them that I'll buy them again unless something were to change.
Cooper Discoverer ATP tires - Reviews, ratings and specs in the Stockton Area - America's Tire
I should add that the Cooper ATP tires are made exclusively for America/Discount Tire. You won't find them elsewhere that I know of. As to the quality, they are very similar to the Cooper AT/3's....but better looking in my opinion.
Here is a good article on AT tires that talks about and compares a few of the major players in the AT tire department. Cooper AT/3s came in 1st overall.
Just food for thought when you consider the ATPs...
Where the Rubber Meets the Road | Expedition Portal
It looks like the Nitto Terra Grapplers are around $160 which is within my budget for sure. Any other thoughts on these that you can share?
Your thoughts?
Hola from another austinite
Crookedcat
