I finally ordered my Cornfed 2/1
keylay31 said:
Ordered Dec. 16th, Recieved Jan. 3rd. Thus I received it two and a half weeks after the order date.
Looks to me like you will be getting them the beginning of next week, I'd say Tuesday or Wednesday.
This is good news. Thanks bro.
I'll be getting 265/70/17 BFG AT KO's shortly after I get my lift installed.
However, I also want to get an HID kit so I may have to put the tires off for a bit longer.
josh220 said:
Ha, maybe.
I just figured since your doing the lift to make it tougher looking and off road worthy .
Did you find a place to do your lift ? or are you going to do a wrench-a-thon.
I have a few people on here who have offered to help out. So i'm going to see when they are available after it gets here. If they are busy, I may have to wait for a wrenchathon.
Decided to find a Before and After photo for you guys. Photos taken on different cameras and in different seasons.
Definitely looks MUCH better. I can't wait to get mine on, if it EVER GETS HERE. Jason must ship it like 10-day ground service to save money because today is about the 21st day since I ordered it.
Wow, GG makes it look like you have two completely different 4Runners.
Lift looks great BTW.
give Jason a call, you never know.
The Update:
It's been almost two years since I'm installed the lift. It has given me no issues whatsoever, and it does show the more aggressive lift.
With all that said, I wish I would not have installed the lift. It gave me no benefit whatsoever except making me think my car looks cooler. Obviously the clearance was not improved, nor did the 2/1 give me much room for larger tires. The reason I wish I did Not install it is because a) it cost money that I didn't really reap any benefits from (not a big deal) b) it has caused me some undue stress due to the fact that my t4r is still under warranty. I read up on all the warranty threads before I installed and am aware of the issues, but I felt like I needed to do a writeup to share these thoughts.
My advice to others: if the t4r is under warranty, don't mess with it. If I had a t4r which was not under warranty, a CF or greater lift is the first thing I'd do, but I really do regret the job. I'm stuck between leaving it on, or taking it off and pretending I never f'd with it.
I'm not sure how you can say that your 2/1 lift did not improve your ground clearance. Sure, there are part of the suspension that do not have more clearance (lower control arms up front and rear axle and differential in the rear), but for the most part the enter underbelly of your 4Runner gained ground clearance with the addition of your lift. This can be very useful in deep snow, where you don't want the bottom of your 4Runner acting as a plow instead of riding over the snow.
By measurement and forum consensus, spacer lifts do not provide any additional ground clearance whatsoever.
Well, maybe your ruler is broken. I have a spacer lift and I definitely gained ground clearance. Like I said, maybe not on the axle or rear differential, or the lower control arms, but overall there is in fact increased ground clearance on most of the chassis. I'll let you borrow my ruler if you (or the forum consensus) disagrees.
A front spacer, regardless of being a topout/preload, should give you 2x the lift height of the spacer.
This is because the spacer is inboard of the actual wheel hub, and geometry will double the lift, regardless of where the spacer is placed.
The rear axle is inline with the wheels, so the rear spacer size is actual lift.
This is 100% correct. Many get confused with how this works, but I couldn't have said it better myself. You can read more about the lifts here:
http://www.burtmanindustries.com/zoomprod.php?id=4run_03_up_liftkit
Most popular kits are the 1" front leveling, and 3/2.
:iagree:
Very true. You do gain clearance in many (not all) areas.
Ambrose67
