i need instructions on setting up my timing!
nj-gilly22
yeahhh i needed a head gasket replacement due to a failure on one side. so i took it apart down to the block. the block is still in the truck but everything else is disconnected because i had to get the heads off. anyway i got them off got the factory gaskets in and wow mine were messed up! the truck was overheating and i checked the water pump and thermostat and both were functional. i had vapor coming out of the exhaust on cold starts, a very light amount of oil actually in the over flow tank. so i cleaned off the carbon and cooked coolant off the heads and block and im ready to re assemble but i have a problem. ive never timed an engine! i know how it works and what it does but as far as putting it back together correctly and not bending a valve or totally rocking the trucks socks i need to know what to do. i took the distributor cap off and cleaned the metal pieces in there cause of the buildup and put it back together. i think the gear might have even spun a few clicks i didnt relaize what i did until after. but i dont know how to tell where the crank is at in degrees or what piston is going to fire according to how i left it. confused yet? for the record i took the cams out of the head cause the cam seals were about to go. please by all means repost on here or if its to much ask for my number so i can do it right. thanks
