I need your eyes!
What do you guys see?
  • Could use another inch in the front
    Votes: 19 50.0%
  • Looks pretty darn level to me
    Votes: 19 50.0%
  • Total voters
    38
I wouldnt change a thing. It looks perfect according to the factory body lines. Mine is exactly the same and I receive more compliments then ever. Now, when I load up for an off road trip it certainly levels out. Three or four passengers full fuel,recovery gear, coolers of food ect, and that amounts up to alot of weight. When im fully loaded im level.
On a side note, with all that "off road" wheelin weight this is why I went with the OME 695's and when wheelin, they work perfectly!
Bottom line, DONT CHANGE A THING! LOL
IMO, leave it. Function > looks
At the end of the day, you're the one looking at it, so do what you think is best. IMO, the added height isn't worth the tradeoffs. You're already pushing the limits of the 5100s. They aren't made for that much lift. The higher the lift, the less down travel you have. Also, by preloading the coils you will have a stiffer ride. Even with my extended travel Icons, I've chosen (after a lot of trial and error) to run them at 1.5" lift. Basically, as low as I can go and still clear my tires. Lower center of gravity handles better, and the ride is substantially better than when I had them at 3.5" lift.
Thank you for all the input guys! I know it's my truck but It's always good to get outside opinions. I think I will leave it be for a while. I have a BL going in so maybe that will make it less noticeable!
Talyn
