Icon Rebuilds
Tusken
How often is everyone rebuilding their icon suspension for moderate off-roading? Stick with ICON recommended mileage? Rebuild yourself or send them in?
Any advice is appreciated, thanks.
rebuild depends entirely on your shock. There is no definite interval.
things that will require a rebuild; dirt and grit getting inside, bending a shaft, pitting a shaft.
pitted shafts will accelerate wear on the wiper seal, and allow grit inside. Once the grit is inside, the seals will wear quickly.
Symptoms of worn seals include leaking, and oil moving beyond the internal floating piston.
If you lose enough oil, there will be a vacuum and the shock will be sticky somewhere within the stroke. If you lose nitrogen pressure, it will be mushy. Both scenarios will likely make a clunk.
more likely though, you will have noisy spherical bearings requiring replacement before you need to replace seals.
if you are handy, have a good bench vise and are organised, there is not much to rebuilding a shock, and it is fun and rewarding.
required tools include a nitrogen bottle and regulator,
a lossless charging manifold
pin spanner (I think these are required for icon?)
good snap ring pliers
soft jaws - if you are replacing a shaft or rod end.
These shocks were getting new shafts and I did the seals at the same time.
The wear band does not require replacement at this time.
In the photo of the shock assembly, the small 1/4" spacer in the middle of the assembly is the only difference between a regular shock and an extended travel shock. I removed these during the reassembly.
I know these aren't Icon, but they are very similar.
I ran Icons on my Tacoma for 80,000, before I sold it and they were still in good shape. I didn't do a lot of wheeling, but I did do some.
Icon shock rebuild
I think Antman has a good tutorial on how to do this. Do a search for shock rebuild.
The ICON website talks about rebuild intervals. Give them a call and ask them. They have a few video tutorials on YouTube also.
I would not preemptively do it until you approached 50-70k. Boots for the rear shafts is key to a long life.
