Icon Shock Rebuild
Jeremy556
At 70k miles, my Icons are past due for a rebuild. Instead of shipping them off and waiting a couple of weeks, I decided to DIY. I have rebuilt and revalved numerous bicycle and motorcycle shocks over the years, but this is my first automotive shock rebuild.
With all the weight I have added (600+ lbs over stock), the 12" 650 springs aren't really up to the task any more. They were set at a ton of preload, and would still blow through travel pretty easily on big bumps, off road, so I ordered 14" 700 lb springs from Icon.
I figured with the front end apart, I would replace my Total Chaos uniballs and bushings. After inspecting them, they are actually fine, but with 40k miles on them, I'll replace them, knowing I won't have to mess with them again for at least another 40k.
Parts List
1 IVD 254100G - 1 gallon Icon shock oil
2 IVD 158508 - 14" 700 in lb Icon 3" diameter springs
2 IVD 611040 - Icon 2.5 shock rebuild kit. There are 2 versions, 1 for IFP, the other for remote resi.
1 IVD 252004 - Icon nitrogen fill needle
2 WSSX-16T - 1" stainless uniball for TC UCAs
4 COM-10T - Upper and lower spherical bearings for the shocks
I'm not going to cover shock removal/re-install, as that is covered elsewhere.
You'll want to back the preload adjuster ring all the way out, then use spring compressors to compress the spring and remove the lower spring mount bucket.
There is very little room between the springs and the shock body, and the coils are pretty thick, so compressing the spring was a bit of a PITA. The 650lb springs only need to be compressed about an inch to an inch and a half. The 700 lb springs will need to be compressed about 3.5 inches, so I will take it to a shop to install the new springs.
Shock with spring removed, and old vs new spring
Seals still going strong
The COM10-T spherical bearing. I have replaced these several times before. While these were still good, they're only about $15 each and don't last very long, so I replaced them while the shocks were out.
The top bolt can be a pain to get off, the steel bolt and aluminum collar tend to want to stick together, so it helps to soak in some penetrating oil and give it a few taps with a drift punch. It is a 1/2" 12 point bolt. The white stuff is lithium grease. Definitely make sure to use anti seize on the top bolt during re-assembly. Both sides of the top collar are threaded. 100 ft lb for reinstall.
The spherical bearings are held in with internal spiral snap rings. Carefully remove with some jeweler's screw drivers and they can be reused a few times. Basically, remove snap rings from both sides, use a socket large enough to contact only the outer race of the bearing, and hammer it out. Get the new one started, install one snap ring, seat it against the snap ring, then install the other snap ring.
New bearings installed and everything cleaned up. Cleanliness is incredibly important when rebuilding shocks.
First step, remove nitrogen charge with the fill needle. I was pleasantly surprised that my shocks were still full of nitrogen and had very little oil above the Internal Floating Piston (IFP). After releasing pressure with the fill tool, remove the fill port.
Next, loosen the set screw on the bottom plate. You are supposed to use pin spanners to remove the bottom plate, but I used a large pipe wrench instead.
Below the bottom plate is a snap ring which holds piston and everything inside the shock body. You have to fully compress the shock with a good bit of force to be able to remove the ring. I used a ratchet strap.
Then pull out the piston over your oil pan and dump out the shock oil. Clean everything with brake cleaner and paper towels. Blow compressed air into the nitrogen fill port to pop the IFP out. Here is the IFP with o-ring still installed, bushing removed, the nitrogen fill port, and the snap ring.
Top nut (35 ft lb, mid strength thread locker), rebound valve shims, piston, compression valve shims, top out washers, spacer, bearing housing. You should use a zip tie or something to keep these in order when you remove them. You don't want to get them out of order.
Foreground, rebound stack and rebound side of piston
Foreground, compression stack and compression side of piston. The top out washers are the larger concave washers on the right of the zip tie in the background.
The bearing housing has 2 inner seals and an outer o-ring to be replaced. The Icon rebuild kit includes 3 inner seals, I assume one of them is for a different revision of their shocks (I hope). Old in back, new in front.
Replace the o-ring on the bearing carrier and the IFP, install the new nitrogen fill port, then re-assemble piston and valve shims on the shaft. Measure the length of the piston fully compressed and set the IFP depth to that level, fill the shock with oil, then re-install the piston. I cycle the piston several times in the oil before installing the lower cap to get air out.
Tomorrow, I'll take the springs and shocks to get the new springs installed, and get the nitrogen charged to 250psi.
Very nice write up sir. Anxious to see how those new coils work out. I'm eyeing some heavier ones myself, but have read an instance where the 700# 14" was just too much and they couldn't get the nose back down to ride height with the adjustment collar backed all the way out. My Fox's came with 600# 13" and after speaking with them about my needs, they recommended I run a 650# 14", so I think that's the route I may end up taking.
Keep us posted on how it turns out. Again, great job and thanks!
Was able to get them charged, the new springs put on, and installed yesterday. At 0 preload, my front end was about stock height, maybe a little lower. I cranked them up about 12 turns to a little over 1" of preload and am about back to ride height I was before, with 3" of down travel. Ride quality is better than expected, not nearly as stiff as the 650s were on a relatively stock 4runner at similar lift.
I would highly recommend the 700s for anyone with bumper, winch, full skids, etc (@WarnerD9). It handles off road much better and no longer bottoms out on dips or going over ledges. My zip tie says I am still using full travel, which I was somewhat concerned about.
Forgot to mention in the original post, the IFP depth and fluid volume. I couldn't find a manual or anything, so I measured the oil removed from the shocks, and IFP depth during dis-assembly. IFP depth was 240mm, and fluid volume about 410ml.
where do you get your nitrogen charged at?
Good question. I wouldn't know where to start looking for this.
Nice write-up Jeremy. I think with my 4Runner being my daily driver I'd want to rebuild these quicker than the 2 weeks required for sending them in for service. Glad to hear it can be done, even if it is with a few more tools than I have (torque wrench).
Most any powersports or bicycle shop will have the nitrogen, regulator, etc. required. I forget which power sports brand uses the same needle fill valve that Icon uses, but you can get the needle from Icon or Motion Pro.
You can also buy a tank, regulator, and other components to DIY for around $200, I hear. I may do that on this winter's rebuild.
If your like me... you probably don't really want to start a side business... But you could offer a rebuild service to offset the nitrogen fill equipment expense...
that's good to know. i will definitely look into that. but looking at my icons, i have a normal schradder valve, i don't think i need a need on them. any thoughts on that? it's the remote resi not the piggy bag.
Thanks for the write up. I'm planning on doing this soon but considering using aviation grade hydraulic fluid instead of buying Icon shock oil. What are your thoughts?
There is no such thing as "aviation grade" hydraulic fluid. There ARE specific hydraulic fluids used in the aviation industry but the differences are the additives and viscosity, not superiority as the word "grade" implies. Just a different application is all.
I would be extremely careful changing the fluid spec unless you know exactly what you are doing and have a 400 level understanding of all the fluids, additive packs, anti foam characteristics and different esters that are being used, both for the ICON and whatever you choose to replace it with.
I was considering using either MIL-PRF-83282 or MIL-PRF-5606H
Wheelers sells the MIL-PRF-5606H under ICON service parts and tools on their website. The MIL-PRF-5606H is a mineral oil based hyd fluid and MIL-PRF-83282 is synthetic. Not sure which one ICON uses but it's probably just aviation hyd fluid.
I suspect all they do is repackage this stuff and mark it up anyways so I figure I'd cut the middle man out. $55 for a gallon is absurd for ICON branded "shock oil"
We use both of these hyd fluids in the military in everything from jacks to landing gear struts.
Edit: my main reservation is seal compatibility... the fact that wheelers is selling 5606 by the gallon under icon parts tells me I probably won't have a problem using it.
Nice Job!
I rebuild shocks on the side here in Denver, PM me if you have any questions.
I've done a ton of Icon/Donahoes mostly for Toyota's.
In regards to the oil to use. I source my oil locally by the 5 gallon pail that matches the specs that covers all shocks that will go on a DD/weekends warrior. Never had a problem, and that includes Raptor's factory IBP Fox's.
Becareful on the specs of your Hydrualic oil, fork oil or ATF. Its better to use shock oil - it is designed for higher heats in an airless environment. Use oil with the highest viscosity index you can afford.
Shock Oil Weights & manufacturers.
ICON - 7wt
King (Shell) - 5wt
Fox Blue (F&L) (Std) - 5wt
Fox Red (F&L Ultra Extreme) (Race) - 7wt
Bilstein (F&L) - 7wt
Saw (Torco) - 7wt
King uses Shell Tellus 22 or 32, and it is not considered to be as good as the oil the rest of the brands use. Most race teams will swap it for Lucas or F&L. The Trophy Trucks use very expensive Maxima oil. You can use Mobil DTE 11M, about $80 for a 5 gallon pail
So after doing quite a bit of research into the fluid to use in my rebuild I've gathered the following information that perhaps someone else could use.
Icon/Donahoe uses a 7w shock oil which I've narrowed down to Torco RFF 7W
The following are the measured Kinematic Viscosity and the Viscosity Index number for each of the fluids I was interested in comparing
-Torco RFF 7(ICON) - cSt @40C 16.10 / cSt @100C 5.05 / Viscosity Index 285
-MIL-PRF-5606H(standard) - cSt @40C 13.20 (min) / cSt @100C 4.90 (min)
-Phillips X/C 5606H - cSt @40C 13.90 / cSt @100C 5.10 / Viscosity Index 365
-MIL-PRF-83282D(standard) - cSt @40C 14.0 (min) / cSt @100C 3.45 (min)
-Royco 782 (MIL-PRF-83282) - cSt @40C 14.20 / cSt @100C 3.51 / Viscosity Index 128
I feel fairly confident that either would work just fine but I'll run with the Phillips 5606H and see how it does.
D'Angelo
