Idle jumping and dropping 550-900
Arnezie
Ok so it’s been getting worse lately to the point when it gets down in the 500’s it shakes a bit like it’s going to stall. Good plugs, wires , MAF cleaned , a/c on and in park. I’ve searched and can’t find an answer anyone have any other ideas ?
Does it do the same with the a/c turned off?
First off, what year and engine - Makes a difference.
-Check all vacuum lines. Unplug and cap off hose to brake booster
-Clean throttle body and IAC
-Test your TPS
-Test your O2 sensor
It’s been hot as hades lately so not sure I will check later.
2000 SR5 3.4L all vacuum lines secure , TPS threw code 2 months ago and was replaced. No codes currently. Throtle body was cleaned 8-9000 miles ago
Might just be the compressor cycling on and off. I'd definitely remove and clean the IAC really well.
My 4Runner just started doing the same a week ago. Haven't had time to see what it is yet. Let me know what the result was!
Ok so it seems to be much better with the A/C off and just idling. Seems more consistent. So it’s related to A/C being on and the compressor kicking in. It didn’t do this before so what’s the issue ?
Your revs might not have changed but if you need a ‘tune up’ you can make the AC compressor cycling more dramatic because the low RPM idle is getting rough.
I put ‘tune up’ in quotes because nowadays shops sell tuneups and they really don’t do anything to ECU controlled cars. Tune up now is more about keeping things douched so the electronics can do their job.
It’s either fuel spark or compression. Oh wait, clogged cat maybe, but that would throw CEL. Without CEL my bet would be ignition. Fuel probs are caught easier by CEL, but still possible.
I’d check how the plugs look. What do you mean the wires are good? They look good or you replace them? Check the connections? Coil packs?
Upstream O2 sensor? Fuel pressure regulator? Pump or filter?
Good luck.
Probably just a coincidence.
If you cleaned the TB but did not remove the IAC, some crap probably flowed down to the IAC and gunked it up. Time to clean that IAC.
Don't forget a new IAC gasket, part #22215-62180.
Don't worry though, I ran with a sporadic idle all winter, and only got to it when it was warm. Just keep more distance to the car ahead, and if needed, brake harder and give the throttle a blip. Keeps it from stalling at a light. (mine was actually okay and would only completely stall 1-10 times, normally the ECU corrects it and saves it from stalling)
I just had this issue with my 3rz. I thought it was old gas because I haven't driven it anywhere in over a year. I was on "E" & added fresh gas & the same thing. It was the battery not holding a charge. It was fine when revving but almost stalling when idling. I killed the battery over the last year by not keeping a charge on it.
Ok so going to order some new plugs it’s been longer than I thought 50,000 since I replaced them. Wow just looked almost $10 a piece for plugs !!! Wow they have gone up!! I’ve never cleaned the iac is there a good write up on this ?
New plugs. Came across this , anyone know what this means ?
Do you have to replace the gasket if I take it apart??
delislerebecca
