If I ever strip the nuts that screws the fuel lines onto fuel filter
Yes, looks to be.This actually happened to me this week .However I only had to cut the line on the engine side though.I just bought a 14mm fuel line fitting with some 5/16 steel tubing + some -6an SS braided hose I had laying around and took care of it that way. I'll try and post up a pic tonight or tommorow.
Hey hey, I’ve had to cut my engine bay side hardline and was not successful in trying to flare it again… not a straight enough run of pipe to make it perfect enough.. I have new 14mm tube nuts.. what technique did you use to securely connect that braided tubing to the 5/16” hard line? I’m interested to see your set up..
Might need this.. You can make the line I believe out of nickle copper if you have the proper flaring too.
77251-3D140 Genuine Toyota Tube, Fuel Main
I made a piece for the sending unit and just bought a union to repair my one rig.
I mostly just replace the lines with oem replacements if they are available as mostly they are not horribly priced. :-)
Brake lines I just make because i have actually had the originals rust out again. :-(. Using nickle copper and stainless steel nuts so they don't ever stick again.
https://www.toyotapartsdeal.com/oem/ toyota~tube~fuel~main~77251-3d140.html
[MENTION=164664]brillo_76[/MENTION] your link doesn't work for me, but I think the following link is what you're referring too.
77251-3D140 Genuine Toyota Tube, Fuel Main)
