I stand corrected. You can lift the rear higher than 23" without problems, but for the front, you should still stay under 23". I currently am at 22.75" in the front and about 24.5" in the rear. I am very happy with the overall height and stance. I like having the rear 1.5-2" higher than the front. It looks right IMO and you won't end up with a saggy rear end once you load up your gear.[MENTION=77310]BrandonF[/MENTION] I remeasured marking the center of the hub with a marker.
PF:21 5/8
DF:21 1/2
PR: 21 5/8
DR: 21 5/8
Diff: 9 1/2
I have no fender flares if that matters.
Most advertised lift heights seem to based on more standard stock heights of 20-20.5" hub to fender. If you decide to go for a lift, be aware of this. A 3" lift will probably only give you 1.5-2" max over your current height.
Yes I am aware, actually asked that question on this board. I am looking to get the toytec ultimate. Since it is adjustable and I can adjust it without taking it off.
The toytec ultimate is definitely a good kit. I went the poor-mans route and pieced together my lift with tundra fronts and land cruiser rears.
Yeah I thoufht about piecing it together but sitting at 21.5~ I am happy with that for now. I have no major rear sag. So ill save the money and upgrade other things for now.
I wouldn't run a 12,000 pound winch unless you replace the rope. A winch that strong will normally have a rope strong enough to go with it, and that's strong enough to tear itself right off your truck. You want the winch to fail before the mount does. I'd go 10,000 at most, 8 or 9 would be better.
Do you live in West Valley? I'm trying to remember if I've seen your truck around.
Is it one of those glue on boots that is cut in half or do I have to take apart the cv?
are you going to give us your hub to fender measurements?
I already did and I just lowered to front to 23" today
