im afraid my timing belt was never changed
You should be ok, as far as the valves go, as long as you're not pushing the motor at high rpms when it breaks.
However, all the material that comes from a shredded timing belt will propably take out cam and/or crank seals and possibly damage the timing cover.
Of course you will be stuck where ever you are as well.
If in doubt, replace it before it breaks.
As far as the valves and internals go, it's either an interference motor or non intereference motor. Non interference, no internal damage when it breaks unless material from the belt causes a problem which it normally doesn't, regardless of the rpms you're at.
Interference, valves get bent even if your motor isn't working hard.
I thought I read on here somewhere that the 3.4 is a non interference motor.
it is a non interferance motor. If the belt breaks its doubtful it will take anything out as far as seals and stuff go. If seen these things go over 200K on orig belts. Dont push it that far but dont freak out if it wasnt done at 90K
yeah i just bought my 97 with 126k on it and i dont see anything saying it was ever changed. i got to get it done.
I'd put off changing the timing belt until your water pump starts making that "squeak, squeak, wrrr, squeak" sound. I switched my belt when I replaced the water pump. If you do it yourself, you have to have a special too to compress the tensioner pulley. Best of luck if you don't buy that tool--a lifesaver!
I dont have the $ to do it...and im at 151k so I'm just gonna take it easy, and when I get paid a few times ill start doin it piece by piece
how much if i do it myself?
That's the price of the belt, plus a little extra thrown in for beer money! That's a great deal. The first time I did it, it took me 6 hours, the second time, 3.5. The tool I mentioned is only 25 beans online, and if you do the water pump I think it costs 175-200, but I can't remember exactly how much.
i would LIKE to save some money and i love working on my ride, so i wouldnt mind doin it myself...
should i wait on the water pump or do it too?
Rialm
