Inno cargo box on Prinsu roof rack?
JFlo76
Junior Member
I've got an Inno Shadow cargo box on my factor rails w/ Yakima crossbars. Thinking of switching to a Prinsu roof rack for more versatility in what I can mount up there, but I'm not sure the Inno box will fit on it. The box has clamps that should fit the Prinsu crossbars, but it also has these dips in it at the nose and tail... see the pic here...
I believe the Prinsu crossbars can be set at any distance along the length of the rails, right? Cuz I'd need to make sure the low dips in the box can fit between the crossbars, and that the dips don't hit the roof. Anyone know how much space is between the Prinsu crossbars and the vehicle roof?
Anyone attempt mounting these 2, or something similar, together?
Only issue I could foresee is that the prinsu rack sits very low close to tbe roof at several locations, so that might or not work depending on the clamp size of the inno and where you want to put it. Another potential issue is that the prinsu rack wind fairing sits higher than the rack. If you get tbe 3/4 version, it is likely to interfere with the cargo box. This is the main reason I ended up with the LFD 3/4 instead.
Ambrose67
