billabongo
Hi,
Longtime hovering and reading and now posting
So here it goes
93 4Runner 3.0 auto sr5 130k
Truck is near flawless and full service history up till dec las year.
Anyways, I live in vegas and its have been having a ton of issues with extreme fuel tank pressure build up.
Now whenI say extreme. I am saying if you take the fuel tank cap off it will vent for nearly 20 seconds at very high rate of air. The best way I can describe it is if you have a large air compressor tank and you decided to purge the tank, you would get the idea.
Doing this also causes the truck if running to run horrible and even stall if i remove the cap really fast.
Also if you start the tuck with the cap off the pressure in the tank is immediate and you can literally hear and feel the pressure at the filler neck and its loud.
So prior to this happening I was having really bad fuel fumes from the evap canistor.
I inspected all the lines, tested the valve per the service manual and blew it out. No issues noted.
I checked all the tank lines from front to back
I pulled the connections and blew air through them, all nice and clear.
I then suspected possible bad fuel pressure reg or pump.
So i put my fuel pressure tester on the rail tested out the system. No issues, 38psi with vacumm line on 45psi without.
I run a key off test and see that the fuel pressure drops off to zero. So bad fuel pump flowback valve or injectors leaking.
Tested out the system and found the fuel pump was draing back.
So using my trusty self made access panel under the carpet, swapped in a new fuel pump.
While there checked all hoses even ran the pump while in the tank so i could view for any crazy stuff.
No issues, fuel return line pumping it back in just fine pump not leaking.
So sealed the tank back up and try out the truck.
Same problems!!!
Though now the fuel pressure holds with key off.
So this time i figure it had to be a faulty evap canister valve and bypass disconnect the canister and cap the lines.
Try again, no change.
I am so stumped, It is such a violent pressure build up I am concerned the tank may literaly rupture, explode or blow the filler hoses.. You know something is wrong when your at a gas station and people stare at you when it sounds like your tank is expolding when you take the cap off lol
So ideas wanted, cause i am stumped.
(Posted from my Galaxy Tab)
So here it goes
Same problems!!!
