Install: Cornfed 3/2, Cooper STT 285/70/17 and Spidertrax
30k on my STT's so far and about half the tread left (eyeballin' my spare unused STT vs. the tires on my truck) I absolutely stand behind these tires, period. Road and rain performance are outstanding. They perform extremely well in the mud but I haven't had a chance to get them into ice and snow.
So far so good. I honestly forget I have them a lot of the time because they require no maintenance. I do have them re-torqued to 85 pounds when I get my tires rotated to make sure they stay tight, but that's it.
Same 1.25" Spidertrax spacer on a Gen III. Without fender flairs they stick out a little. Sock offset on TRD wheel 265x75x16 tire.
Nice 4Runner. I run 30-35 psi on road, and 12-18 for trail crawling.
Do you have any shots of that from further back for better viewing? I'm curious to see if it looks as good with the whole truck in view. Thanks.
update: just got my tires yesterday, and they are SUHWEET! Im very excited about getting them on monday or tuesday. PICS to come.
OH YES
just got home from toyota, had a 50k service/checkup and the spacers and tires put on aswell. THE TRUCK LOOKS AND RIDES GREAT! i love the smell of fresh tires!
Now im debating on whether or not to wait till i get the wheel spacers re-tourqed to go offroad.
I am VERY HAPPY! The tires and spacers balance out the rest of the lift and stuff perfectly, not too big or small.
I estimate pics will be taken this weekend or sooner!
:bigok: :biggrin2: :bigok: :biggrin2: RAY :bigok: :biggrin2: :bigok:
ive had my lift and stock tires for 9 months, thats WAY TOO FVCKIN LONG! weeeeeeeeeee
i ended up using a nice sharp filet knife, which also treated the plastic like butter :-D
For those who have trimmed their inner lining: are u concerned about the back of the foglight being exposed to water? and how are u dealing with loose parts of the lining and potential flapping
Re: OH YES
You knew it was coming.......
:worthless
Not too worried about the fog lights anymore. I was at first but I have had them exposed for a little over a year now. They have been caked with mud, drenched with water and even sprayed at with a pressure washer and everything has held up.
I trimmed the plastic high enough to where I don't experience any flapping.
hey trik, in this pic, im concerned about the piece of thin lining that remains on the right(outer) edge of the wheel well. This piece used to be connected/stabilized by the plastic triangle that we've cut off, so now at its tip its not connected. maybe i cut too much? but i imagine that since ou rounded out your fender corners you removed more than i did....
000_0027.jpg~original
i feel like im not being clear?
I'm kind of confused on what you are asking...but as a blanket statement, I trimmed a hell of a lot of plastic. The plastic triangle is gone, you can see I rounded the bumper (probably overkill but I didn't know what to expect when the tires stuffed into the wheel wells offroad) and I took the inner plastic lining just above the washer fluid housing. In my pic that you pasted, you can see where I had to patch the washer fluid box with tape momentarily because my dremmel actually burned through it, causing the box to leak (oops).
BillM777
