michael90630
I am trying to install Shrockworks rock-sliders on my 2007 T4R SR5 V6 4WD.
I ran into some issues on the driver side. It seems like others in this forum had similar issues but were able to ultimately resolve them and looks like everyone with Shrockworks sliders are quite happy.
When I am trying to install the front driver side slider U-bracket onto the frame, I am having the following issues:
1) The 6" bolt is supposed to go from inside out i.e. the nut should be on the outer side. But brake-lines are in the way and it is difficult to position the bolt because of the interference from the brake lines. Did everyone who installed this slider have to just un-hook the brake lines and drop them down? There are two sets if plastic (white) fasteners/mounting brackets for the brake-lines. Do I need to separate the brake-lines from both?
There are pictures in the toyota120 forum which shows the location of the slider U-bracket in relation to the brake lines.
http://www.toyota120.com/forum/showt...hlight=sliders
http://www.toyota120.com/html/shrockworks_sliders.html
Expat did note that SW should try to streamline this install a bit - and I 100% agree!! The installation instructions does not mention anything about re-positioning the brake-lines. It's mentioned implicitly in Step 9:
"Tighten all six bolts and reinstall any unclipped lines or removed pieces."
2) Without bending the 6" bolt, how do you get it thru the inside slider U-braket hole and over the frame to the outer hole of the slider U-bracket? It's a pretty tight spot.
Thanks.
Thanks.
