Installing hd billies need help with torque spec
WHORERUNNER
Im planning on changing my stock shocks with some regular hd billies. I cant find torque specs. Well the only thing I found was 14ft lbs on rear top nuts? What about lowers and also the fronts. I'm planning on taking the struts to a shop to swap the shocks out. Any help thanks.
Torque until real tight. I didn't use a torque wrench on mine.
^this, but I'd say just tight. Not "real" tight. There is rubber between everything you are tightening, don't fret about a torque wrench. Just make it tight. It's possible to completely smash and misshape the rubber bushings if you go crazy tight.
