Installing TRD Pro Grill
dafuture
Hi All,
I got my Pro grill recently and I'm hoping to install it tomorrow.
I noticed the instructions call for 3M GPAC, but that doesn't seem to be available unless you order online. Is there something else I can use in it's place?
I was thinking of using this Goo Gone Adhesive remover, but I'm not sure if there's an issue with the compound that helps the 3M Tape on the grill adhere.
The garnish comes from the factory with double stick tape. What are you using the goo gone for? Are you trying to remove the factory adhesive and stick on your own?
You can use your regular 3m outdoor 15lb doubel stick tape from any hardware store.
Op, i think you are overthinking this. The grill comes with all you need to mount. If you want to clean the bar/grill area before mounting the pro grill, just prep the area with rubbing alcohol and be done with it.
I just used windex I had lying around the house to clean the area.
erinobr2000
