Installing trdpro suspension on sr5
Hbryanlopez
I just bought a set of trdpro suspension and the install looks pretty straight forward. My question to those who has done the install, what are you guys using to bolt on the reservoir to the rear? Does the 2011 sr5 have pre drilled holes for them?
The rear shocks should have come with brackets that attach to existing holes in the frame. If not, you will have to get clamps that attach the reservoir to the shock body.
I have the brackets but I do not have the bolts.
I haven't done the install of TRD Pro shocks but since they are pretty much Bilstein 5160s, can you mount them the same way? Looks like the 5160 resis are installed by hose clamps. I can't tell how they are attached to the frame though.
I have the clamps but still need the bolts, I was just at Toyota and they couldn't find the part #. Will do some more digging this morning to see if I can find it.
I still have the old bolts on my truck. I forgot to take them off. Swing by later and I'll give them to you.
goddesszilla
