Instrument cluster Auto trans indicator lights???
KYMUDD
Ok guys need a little help from you instrument cluster and dash lights pros. I noticed the other day that my auto trans indicator lights in the dash doesn't come on in the D or drive position but, Park, reverse, neutral, 2nd and low all light up in there postions it worked previously. What can cause this? Is there a fuse blown a light bad or what anybody had this issue before?
Thanks in advance for any help!
Chris
I'm no pro...but my guess would be the bulb if all your other lights around it work, I don't believe they have individual fuses. This would be the perfect excuse to do the LED swap though if you decide to pull the cluster out:eyebrows:
Lol I figured it was a bulb. How hard is it to get to to change bulb. I don't know if I'm brave enough to try the color change!
Talyn
