Instrument cluster intermittantly wonky
Toyoter
Junior Member
Hello,
I hope you guys can shed some light into a strange issue. Vehicle: '05 4R LTD 2WD V8.
The instrument cluster gauges are intermittently going wonky. They'll all read randomly on any given drive (tach near redline while actually idling, speedo reading 60 while stopped), temp gauge pegged below cold while at 192* and so on, so sometimes some or all of them wag around while there's no change in what their reading should be. Once they act up, they seem to stay acting up for that key cycle. The next key cycle they can be fine (or maybe not), except the fuel gauge, which now seems to have permanently re-indexed itself to reading 3/8 of a tank when full (the mileage remaining readout seems accurate however).
Is there anything I should check (connectors, a dedicated ground for the cluster, etc)? Do these clusters chit themselves often? I assume that if one procures a used replacement cluster, a speedo shop is needed to set the vehicle mileage?
FYI, there's been no recent work done to the vehicle.
I tried searching but didn't see any overwhelming answers to similar issues. I really welcome any thoughts you might have.
Thank you
I figured that was an unusual issue - sorry guys.
Since I might need to procure another cluster, do you guys know if there's a difference between the clusters from trim level to trim level (e.g., do Limiteds have a different cluster than SR5's, or V6's have a different one than V8's)?
Which model years are the same/interchange?
I would check the connection (both of them) behind the clusters. Only other issues these clusters have are the stepper motors (the motors that move the needles) sometimes go bonkers.
You have a 2005 Limited 4x2 (V6?) ? Then get a cluster from the exact model. Cluster design varies from SR5s, sports, and Limiteds. V6 vs. V8 too. Also, if you have (or don't) air suspension, get a cluster that contemplates that. I've seen any 03-09 cluster work with any model (speedo/tach/gas/etc), but the little things may not work. (such as airbag light, cruise control lights are different as are turn signal indicators......... etc etc etc).
Hope this helps,
Hope this helps,
Thank you sir. It's actually a V8 (I just added that to the original post). Great to know that I really need the same year and exact trim/specs of a donor cluster (though it makes getting a used one that much more difficult).
If just one gauge went bonkers, I would be all over the stepper motor idea. Since every gauge has gone nuts (starting all at once, all stopping at once), I'm more inclined to think it's something upstream of the cluster (power supply, ground issue) or a pandemic issue across the cluster itself. I think the gas gauge is a separate issue now; I think when it spazzed it threw itself out of 'orientation', so 1/2 tank is the new 'Full'.
I was hoping there was a known ground location or a known issue with the connectors. I will say that it can be parked in the garage acting fine and when restarted, it acts up (so it's not like it requires NVH to set it off).
Thank you again for the post! I really appreciate any help I can get!
Check your battery grounds really well, and then inspect the fuse for it (dome maybe?) It isn't unusual to have a partially broken fuse. After that, I'd pull the cluster and check connections, esp if anyone's been in the dash before.
