intake manifold gasket questions
willyt4r
My 91 3 VZ intake manifold gasket is leaking. ( 188,000) miles. what are the other items to be replaced while the plenum is off.
1. valve cover gaskets
2. injector o-rings
3. timing cover gasket
4. knock sensor wiring
5. ? ? ?
Thank you for your help:peace:
What is your intake leaking? Coolant I'm assuming? If your talking about the lower intake be sure to replace the timing belt, all the coolant hose's, check, double check and triple check the water pipe under the intake, it is notorious for leaking and or developing holes in it.
Tell me more about what's leaking and I'll tell you everything I just went through on my engine install on my 91. I just got it running on Oct. 30th and after the first turn of the key it has purred like a kitten ever since, and I mean from the first crank of the starter.
Bryan
intake mannifold gasket
she is leaking air on top the #6 cylinder. Smoke test showed the Air intake manifold gasket
Well, heck if all you have is a vacuum leak then your are one luck son of a gun.
The upper plenum is a breeze to remove! I would r&r that upper plenum, replace the heater hose's going to the pipe that flows under the intake, the two that connect coolant to the throttle body, of course a new upper plenum gasket, and I would buy new vacuum lines because I can amost bet that many of yours are old, dry rotted and leaking vacuum. Now, as for all the vacuum lines on the passenger side of the plenum I'd leave them all connected to the plenum, unbolt all the vacuum switching valves on the passenger inner fender by removing the two 10mm bolts holding the bracket holding the vsv's to the inner fender and remove the two vacuume lines to the power steering pump. It couldn't hurt to lable the lines you remove with masking tape and use a sharpie to lable where they go.
Just take your time, loosen up the bolts holding the plenum to the lower intake, remove the two nuts, remove the accel cable, kick down cable and cruise cable. unhook the tps and lift off the plenum.
I would use a razor blade to scrape off the old gasket from the upper and lower intakes, and I'd also take the time to clean the throttle body with tb cleaner and a tooth brush.
Oh, i'd also put paper towels in the intake runners to prevent gasket material from falling into the lower plenum, or upper if its stuck to the upper.
Good luck!
intake mainfold needs planning
In the ongoing repair for an intake manifold gasket leak. The manifols itself _ after 19 years_ needs to be planned.
Curious side note- my local toyota dealer ( Crown) did not have the intake manifold gaskets in stock. Had to use Felpro.
I'd replace the following:
-all the injector seals(upper, lower, housing/holder o-ring)
-fuel line copper gaskets, 8 needed
-valve cover gaskets(because you have access at this point)
-pcv
-both upper and lower intake gaskets
That's all that comes to mind right now.
regards
burnt intake valve #6
the deeper we go the more troubles we find. What was a intake gasket has morphed into rebuilding the cylinder heads/ head gasket $ 1800 and a week downtime. - So it goes.:violin:
S
more issues
While the engine is being torn down- must replace the water pump, belt, thermostat and radiator . Tack another $400 to the price:roadkill::happens::happens:
