Interior Light Conversion 02'SR5 4WD
MrOmarion
Hello
Doing a interior light conversion on my 02'SR5 4WD
I will be uploading my progress as I go
1. Here are my parts ordered
Imgur
2.Removing Center Console
Pulled Up and used a small flathead to pop off some tabs and create space to pop off the piece covering the hand brake. Then much more easily, I pulled up on the gear shift piece and it popped off.
The bulb for me was under my Neutral, I don't recall the last time it worked. Either way turned I turned it counter clockwise and pull down with some struggle. I used needle nose pliers and it came off.
I pulled on the bulb and it flew off so I did get to check polarity. I installed the new bulb and put everything back for now. Turned the car to accessory mode, all other lights work. Not sure if polarity is incorrect, wiring or the #74 Bulb I installed. To be continued
http://imgur.com/4jlVIQC,KBgcwwy,iHENjXU,LTR7m2s,153KAn3,AtSAu1a,G17Qdq1
Worked on it some more, sorry for the late update
I did the keyring light around the ignition, the climate control knobs, the very pesky rear window switch and glove box. Its all about finding the right tabs and a small flathead screwdriver should really help make things go easier.
Heres a link to the imgur album pictures
http://imgur.com/QgPAjro,jswiFib,kw...K1OZ3,MhEsADC,dKPKMAc,Rz8UAGN,z0zaBBC,HFboe8W
More pics posted in imgur links above, below are just some of the shots. Sorry i dont know how to make pics appear small in this thread
1.
2.
Edit: Flipped the LED, Shining bright now
utkrstam
