Interior trim question
snif6969
Bought my 2015 TRDP used and I notice a hole in the small cubby holder on the dash.
Anybody has an idea of what is was for ?
Or what can I use it for ?
Since the hole is already there, might as well use it !
Thanks.
I would guess the previous owner had a power wire coming out of there for something to power an accessory device they had sitting in that spot? Check the fuse panel and see if they added a circuit maybe? Then again they probably pulled the wire back and out too. That would be my guess... wiring came through there for something, push button hidden switch :suspicious:
So let's try to brain storm....
What would you put in there that requires a constant power input that cannot be given by the cig. charger ?
That's where I have my remote subwoofer control mounted. It's the perfect space for that purpose, but an otherwise useless compartment.
I don't have the velcro, but I did cut a hole there to route the quick disconnect and cable for the CB hand unit in my truck.
Okki
H.Sikina
