Here's the data:
Same bump height for all arms fully stuffing a 35" tire up to the stock fender, but more droop for the longer arms. Unless otherwise specified degrees are toe-in at each tire. Double the numbers for total toe. Stock geometry spindle and rack position stayed the same. Assuming .5* toe in each tire at ride height.
My analysis: Bump numbers are all the same and close to ride-height toe. The more downtravel you have the worse the LC200 rack bumpsteer is. And for the love of Toyota don't put a clevis on a LC200 rack without optimizing the rack position and spindle geometry.
(With a 35" tire, 1* is equal to .6" of bumpsteer. My rookie guess is that under 1* to 1.5* or .6" to .9" is optimal for all driving conditions.)
I ordered from best to worst:
I don't think my build thread gets much traffic but does anyone think there is a market for fabricated spindles using the factory mounting points? In the $1500 range.
Good option for those with standard LT kits that need more strength.
Sourcing unbent spindles on Ebay:$300
Spindle gussets and double shear tabs: $150
Paying a welder: $250
Total: $700 for alternative
Unfortunately need at least 10 people interested in order to make it work financially.
Like this but for the factory style UCA:
Thanks for getting this laid out, it certainly does help get the visual for the various setups.
I can see this being a huge issue (possibly?) for high-speed desert guys like you mentioned. I have no concerns going with the LT arms and LC200 rack since it looks like on the street it's quite similar to stock, certainly not all too awfully worse.. if I had to guess.. (with absolutely 0 test data to back this up) I would say I would say that I would be very surprised if I saw more than 2 inches of down travel up front during street driving.. my biggest down travel up front on the street comes from taking off on the stoplight if I hammer down, or if I'm cornering REALLY hard (which the TK1 Sway bar in the rear REALLY helped out recently). Obviously I would expect tire wear to be worsened quite a bit if the toe-in is changing drastically with one side approaching near full bump, and the other approaching near full droop (this would be super hard to do with regular street driving on an LT set up?). For rock crawling applications I have no concerns about what each tire is doing as far as toe. I'm never in a full droop or full bump with both wheels at the same time, and in the instances where either is at an extreme, I'm usually lifting a tire, or at least unloading quite a bit of weight off of it.
As far as the clevis.. I can see that being really handy.. but with the numbers that you get with it on top of the additional cost of getting the clevis I would probably lean towards just fabricating my own outer tierod and leaving the inner as is.. that way the factory boot can stay on with no issues as well.
At the end of the day I guess it could also be possible to cut the rack down a bit? Though at that point I would kind of wish I just went with a Tundra rack to cut down to begin with lol.
Are you looking to try to get 10 total between factory mount & the modified mount? If I had to guess I would say the 4th gen market would be tough to do..I would imagine you could get 10 folks onboard for a weld-it-yourself LT Arms that use the factory spindle a lot quicker than 10 people to get on onboard for an upgraded spindle.. but I could be wrong. I don't know how many 4th gen guys currently are even on a non-factory spindle outside of just doing the gusset weld-kit and calling it a day.
I wonder if you make the caliper bolts larger for the later 5th gens (I think it's M12 vs m14), then you might be able to get more buy-in. There may be some other small changes, that I'm not sure of.
Hey Mason,Here's the data:
Hey Mason,
I may have missed something, and I'm probably reaching a little here. Your numbers have a +4.5" Control arm factored in. Could the DK +3.5" arms be a little more forgiving in the BS figures? Or most likely worse w the 200 rack?
I also have the 200 OTEs I could experiment with, or am I way off base w my thinking?
All things aside I'm impressed with your drawings and would love to learn some CAD, and my geometry skills could use a hell of a lotta work.
That Top Hat is a great idea.I would say its similar to the +4.5" arm numbers, maybe a little worse.
I think the bumpsteer really just depends on how much downtravel you are getting. 12.5" of travel is good for a +3.5" kit, but low for a +4.5". The numbers above are for my +4.5" arms at 12.5" of travel, but they should be capable of 15" of travel.
Anything you can do to shorten the tie rod mounting surface or pivot points will help. Either by machining down the mounting surface of the tie rod ends or machining down the rack ends if possible and installing a tie rod with a shorter bolt or threading the rack deeper.
Speaking of travel, I was going to design my own coilover top hats to mount the shocks a hair above the coil bucket to maximize travel. But I found Fox already makes a top hat for their IFP Toyota shocks that does just this. I got the part number from Fox just need to find them in stock from a distributor or backorder them.
206-06-085 – mount adaptor
214-39-125-2 - spacers
018-04-014-A – bolt
I just measured the two OTEs, the 200 is 1.1" shorter than the Tundra. I will have to rig up a good way to measure toe thru the cycle and play around with them a little bit.
I have a fab guy w a good CNC machine, so maybe I can machine and adapt a little.
Figuring out a reliable measurement system for that much travel, will be a challenge.
The shock therapy guys have aluminum plates they bolt to the spindles and use a fork lift to cycle the suspension. Dont have that luxury....
Whats crazy is Devon says he doesnt notice much BS on the FJ at all w the Tundra OTEs.
Although I might be pushing the top speed on my rig to where it could get exponentially worse and send me on a death roll lol.
Ah you said outer tie rod ends. I was reading it as inner tie rods. Outers don't effect bumpsteer at all. They don't effect the pivot point distance.
For bumpsteer you simply need to know the distance between tie rod 'ball joint' pivot points or heim pivot points if you have heims. Nothing about the tie rod between those two points matter.
To reduce bumpsteer with a wider than factory rack you need the lengthen the distance between these two points.
so we're talking about the inner pivot point of the control arms in relation to where the rack pivot point is, correct? Hence with the wider rack the inner point of the rack is pushed further away from where it should be, effectively shortening the arc length as the suspension cycles. This is the reason it doesn't matter at all what length LCA/UCA combo is, since the relation between these two distances will remain a constant proportion. I'm assuming that is more or less in line the reason of bump steer with the wider racks, correct?
if so... can we entertain the absolutely crazy idea of moving the subframe pick-up points outward??would this, at least in theory, work? Or am I missing something completely here?
[MENTION=582805]aemravan[/MENTION] these damn engineers just keep crushing our dreams lol.
