inverter using add a circuit?
i'd like to hook up this inverter to my 07 T4R using the add a circuit option, with a possible switch between them. my goal is not to use this inverter to charge refrigerators or anything that draws a lot of power, or even to make it a constant on mod. i'd use it for charging my camera batteries, since i'm always on the go, and the occassional macbook.
is something like this possible?
yeah you should be fine. i use one a bit larger for the same use (computer, phone, lights) and it fits nicely under the driver seat while it plugs into the cig lighter.
but you can very well hard wire it up and it should work fine. do some searching because others have installed outlets under the driver side seat.
I installed a 150w tripplite inverter using add a fuse, the tripp lite was nice because it did not have a fan. it was only one outlet.
7ron
