irwin bolt extractors
  • Thread starter Thread starter cangler
  • Start date Start date
C
cangler
Guest
I had rounded off one of my 12mm bolts on the skid plate, and i spent hours trying to figure out a way to get out... because it's in a tight spot you can't grasp it with vice grips or anything like that, seems to be only room for a socket with extension. anyways i searched online for options and I found these irwin bolt extractors and the reviews seemed good so I gave the 12mm a shot and I hammered it on the rounded bolt head the best i could with a rubber mallet and the bolt was loosen within 60 seconds. I couldn't believe it worked that well. so if anyone has trouble with tight spot rounded bolts, give these a try. I was impressed enough to share my experience.
Amazon.com: Irwin Industrial Tools 394001 Bolt-Grip Bolt Extractor Base Set, 5-Piece: Home Improvement
Bolt Extractors - Screw & Bolt Extractors - Tools - IRWIN TOOLS
I bought a set of the Irwin bolt extractors as well for removing my rounded skid plates and have used them on on several applications since. Great tool to have in the garage!
AndiGarage
