Is anyone running 245/75-16 tires?
skategoat
The online tire size calculators tell me there is only a .-3.5mm difference in diameter from a stock 265 70 16, yet a tire guy I talked to tells me it's a bigger difference and doesn't recommend the change. Not sure who to believe.
No typo.
I'm talking about 245 75 16 instead of 265 70 16.
I think I may know the source of the confusion.
http://www.miata.net/garage/tirecalc.html shows the circumference difference as 1.5 inches. That's the size difference the tire shop referred to - 1.5 inches. Is that a lot?
Revolutions/mile is 662 (the 265) vs. 659 (for the 245). That translates to .5% speedometer error. Big deal.
Or is my math all wrong?
Sizes...
The 245 75 16 design diameter is 30.47". The 265 70 16 design diameter is 30.63". A 0.52% decrease. I was planning on investigating getting that narrower tire for the next set of winter tires but I have to run out the Dunflops first.
The guy at Steelcase is telling me not to do it. He says there is a big difference is size. I don't see how .5% is a big difference. You would get .5% speedo error between new and old tires.
I'll let you know what happens. I'm going to call around.
Fit...
They will fit. You will have a slightly narrower tread (better in snow?) and more sidewall (possibly softer ride). Shop around for someone more knowledgeable. If you get a tire with a deeper tread then it might even make up the diameter difference.
I called Kipling Tire in Etobicoke. Right away, the guy recommended 245 75 16. Suggested BF Goodrich Winter Slaloms at $145 each installed. Good price, nice guy and close to home. I'm headed there this week.
increasedc
