Is "Hitch Shackle" a good idea? Also, recommendation for a tow strap.
This is what I got for mine:
Serves as a step, recovery point and got a bit of design to it
I have a smittybilt hitch shackle that i've used multiple times. ive recently purchased a hi lift jack mount that also has this type of shackle mount and the whole thing is on the winch.
Thought provoking thread! It led me to read about rating factors for hitch pins
https://www.extension.purdue.edu/extmedia/ppp/ppp-94.pdf
Hitch pin attach point - - - If the strap is pulled at an angle the load on the pin is uneven so a hitch pin should only be employed for a straight pull. Pulling at an angle can also cause chafing of the strap against the edge of the receiver.
Bow shackles' curved surface allows a wider variation in safe pull angles
images
Many times it is difficult to set up a recovery for a straight pull
ServerCalls.aspx
Some hitch shackles are drilled to allow vertical and horizontal orientation for more versatility
^Great recommendation. The pin is extremely important.
I’ve recovered and been recovered multiple times using the receiver hitch with a quality hitch pin, shackle, and tow strap rated to 30,000 lbs. I’ve also used these items to pull massive tree stumps around my yard after cutting a huge oak tree down. This method has proved safe and effective. Just don’t be one of those morons that shock loads the system...it’s painful to watch.
