Is it easy to install the HID Kit? or pay for installation?
JAC
Or would you recommend for an expert to do it.
I am thinking on doing it myself but not sure if is a good idea?. Never done this before so I need some advice from any of you guys that have done it .
Thanks in advance.
It's very simple. Shouldn't take you more than an hour to do it yourself. Don't waste the money to have it installed. Plan where you're going to put each ballast and route the wire and you should be all set.
Very easy!!!! If you can change a regular headlight bulb, you can do this. Just make sure the kit you get has the correct connectors for the plugs on your vehicle.
1. Unplug stock bulbs
2. Insert HID bulb
3. Mount Ballast
4. Route wires and connect all the plugs
I suggest getting the relay harness to protect your stock wiring from any possible damage.
Do it yourself, you'll feel better and save money. I used this great writeup done by 4RunnerRon, a senior member in this forum. I used this write up because I also bought my HID kit from XenonDepot. I'm sure all kits are created equal and 4RunnerRon's write up will work with any application.The hardest part is trying to decide where to route the wiring, other than that, it's about a 2 hour job if you decide to take out the battery.
http://www.toyota-4runner.org/showthread.php?t=16283&highlight=4runnerron
Thanks everyone for your advice ...I really aprecciate it.
I am gonna give it a try...if I have time..this weekend..but no later than the weekend after.
delislerebecca
