is it my ball joints or axles squeaking??
01t4rnr
Mods in sig. but in the past couple weeks ive noticed only in paved areas such as grocery store parking lots and such my truck squeaks somewhere in the front end. at 80% or better turned either way i can be going slow and it sounds like my tires are squealing but they arent. Havent noticed it any other time and drives fine. Would you guys think its likely axles or ball joints? no popping and its not power steering pump. Thanks for any help!
My guess would be your outer tie rod ends (which connect to the lower BJs) are starting to sieze/bind up. Have a friend turn the steering wheel back and forth through the whole range of steering and see if you can see/hear where it's coming from as you lay under there.
wwarren702
