is it ok to drive with leaky axles?
RazzRoach
I have a leak coming from both front axles which the dealer diagnosed as needed entire new axles.. However there is no vibration or noise from axle which leads me to believe I need new seals or boots. I'm planning on driving 500 miles shortly and wont have time to get the work done before my trip. Is it ok to drive these distances with the leaky axle?
Can the dealer give you a loaner and you can drive that or you can rent a car and have your truck ready when you get back. If it were me and both my front axles were leaking I would not be driving 500 miles specially if the dealer wants to replace both.
I ran with leaking boots for a year and it was fine. Had the dealer replace both of them for $900.00. A local shop quoted me $800.00 so I went with the dealer.
Check around and get quotes and check the dealers web site for coupons. Tell them you have AAA and they may give you a discount. Also, haggle on the price with them. Try to get a good relationship with a service manager/advisor, that helps.
The point of replacing boots and repacking with grease is to prevent having to replace the axles. It's cheaper to replace the boots than the entire axle. If you do nothing, you may be fine but you may not. If you fix the leak properly you will not have to replace your axle.
List price on each axle is $500. Cheapest I’ve found is 430. Axles plus labor makes it add up quick and I only want to go with oem axles
Not sure what year you have but for my 2004 McGeorge Toyota sells the axle for $354.44.
You can check for yourself, not sure what the shipping would be but you could save yourself some money if you can get these and have an independent shop installed them.
Toyota Parts | Toyota Online Parts | Genuine Toyota Parts | Toyota Parts Online
Are you sure they are recommending to replace the entire axle vs the boots?
There is no reason to replace the entire axle if the leak has just begun. You can't determine an axle replacement is needed just by looking at them while still installed on the vehicle?
here is the culprit
photo came out blurry for some reason!
That's where mine leaked from. I bought the clamps before I lifted my 4R. It started leaking immediately after the lift, so I swapped out the clamps and it fixed the leak.
AndiGarage
