Is it worth it to get these fixes done?
Ah ok thank you! So it doesnt matter if its cracked right?
This feels like we are being trolled.
It is called split loom, because it comes like that. The split/crack is how you get the wires inside of it. That's exactly how it is supposed to look.
-Charlie
Honestly, that sounds like a lot of repairs for someone that is admittedly not mechanically inclined. Those fixes may be needed to get the 4Runner tip-top, but it is obviously still running now. How does the frame look? You should definitely confirm it is rust-free before the purchase. Minor surface rust is fine, but scale and/or holes would make me walk away.
front sway bar stuff is super easy, napa sell both the brackets with bushings for $49, those bolts are 18lbs. Make sure you rotate tighetning them down, one then the other so the bracket sits perfect and doesnt brake again.
pretty simple job, and can replace endlinks bushings while you are in there, energy suspension has the good red urethane ones.
Jesse1
