Is this engine noise normal?
coltonbaxter31
I can't exactly locate it but it sounds like it's coming from either the belts or the fan. It sounds like it's just having a hard time turning or something I'm not exactly sure. It just sounds "off" when it idles. I used belt ease and sprayed down all the belts.. I have a video clip and you can hear it best at the very beginning and very end of the clip. I might need a new clutch for the fan? Not sure
https://vimeo.com/102936466
Hmm - that is different.
I'm sure plenty more will chime in but I don't think its normal, comparing it to the sounds mine makes. I mostly hear fan roar at first then it calms down (unless it's 105 outside!). Your vid sounds like a bearing is going out somewhere in the front of engine, have you done the 'spot' listening with a diagnostic stethoscope maybe?
Could be a bearing. In the video in sounds like it goes up and down. Bearing noises tend to be more steady in pitch, but it could just be the way the mic is picking up the sound. Easiest would be to take the timing belt cover of and look at that first. There also two bearings in there (idler and tensioner) Then you have your fan clutch bracket bearing and finally any of the accessories (ALT, PS, AC ) As someone else suggested, one of those stethoscopes would be handy or else you'll have to loosen belts and spin each component by hand until you find the guilty culprit. Good luck! Let us know what you find.
I'd call that a bearing too.
Like a crankshaft bearing?
you could try taking the accessory belts off one at a time and see if the AC, alt, or power steering pump are potentially the source.
I have had a timing belt tensioner seize on another vehicle causing the timing belt to break. Thankfully it wasn't an interference motor. We're good in the 4runners that way as well, but just pointing out that those tensioners and idlers do go bad. It's a good idea to replace whenever you change the timing belt.
I know it's not the ac or power steering .. I'm going to change the timing belt sooner than later and ill just do all the other ones as well
delislerebecca
